PLease Help He
sukalyan chakraborty chakraborty.sarkar at gmail.com
Tue Jul 4 01:11:59 EDT 2006
Hi
I'm Tll now facing same problems.
Is there any more solution ???
I've checked the framework version & keeping the bin folder inside the
samples
& also keeping the all dlls open from  the bin folder.
Inspite of that i'm getting same error.
On 6/30/06, sukalyan chakraborty <chakraborty.sarkar at gmail.com> wrote:
>  please help me...
> When I'm Running pages from MGStudio then it is running fine but
> If I running like
> http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
> or
> http://localhost/mapguide/dotnetviewersample/dwfviewersample.aspx
> then getting the error
>  I'm using Framework v2.0.50727 Server Error in '/mapguide' Application.
>  *Compilation Error* *Description: *An error occurred during the
> compilation of a resource required to service this request. Please review
> the following specific error details and modify your source code
> appropriately.
> *Compiler Error Message: *CS0246: The type or namespace name 'OSGeo' could
> not be found (are you missing a using directive or an assembly reference?)
> *Source Error:*
>    Line 17: <%@ Import Namespace="System.Collections" %>
> Line 18: <%@ Import Namespace="System.IO" %>Line 19: <%@ Import Namespace="OSGeo.MapGuide" %>Line 20: <script language="c#" runat="server">
> Line 21:
> *Source File:* c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx
>    *Line:* 19
> Show Detailed Compiler Output:
>   C:\WINDOWS\system32> "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe" /t:library /utf8output /R:"C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll" /R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll" /R:"C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll" /R:"C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll" /out:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.dll" /debug- /optimize+ /win32res:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\3tjlg3zd.res" /w:4 /nowarn:1659;1699  "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.0.cs" "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.1.cs"
> Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
> for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
> Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
> c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(19,11): error CS0246: The type or namespace name 'OSGeo' could not be found (are you missing a using directive or an assembly reference?)
> c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,24): error CS0246: The type or namespace name 'MgMap' could not be found (are you missing a using directive or an assembly reference?)
> c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,1): error CS0246: The type or namespace name 'MgLayer' could not be found (are you missing a using directive or an assembly reference?)
> c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(55,26): error CS0246: The type or namespace name 'MgByteReader' could not be found (are you missing a using directive or an assembly reference?)
> Show Complete Compilation Source:
>   Line 1:    <%--
> Line 2:    Copyright (C) 2004-2006  Autodesk, Inc.
> Line 3:    This library is free software; you can redistribute it and/or
> Line 4:    modify it under the terms of version 2.1 of the GNU Lesser
> Line 5:    General Public License as published by the Free Software Foundation.
> Line 6:
> Line 7:    This library is distributed in the hope that it will be useful,
> Line 8:    but WITHOUT ANY WARRANTY; without even the implied warranty of
> Line 9:    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
> Line 10:   Lesser General Public License for more details.
> Line 11:
> Line 12:   You should have received a copy of the GNU Lesser General Public
> Line 13:   License along with this library; if not, write to the Free Software
> Line 14:   Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
> Line 15:   --%>
> Line 16:
> Line 21:
> Line 22:   NameValueCollection GetParameters()
> Line 23:   {
> Line 24:       return Request.HttpMethod == "GET" ? Request.QueryString : Request.Form;
> Line 25:   }
> Line 26:
> Line 27:   void InitializeWebTier()
> Line 28:   {
> Line 29:       // Initialize web tier with the site configuration file.  The config
> Line 30:       // file should be in the same folder as this script.
> Line 31:       //
> Line 32:       string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
> Line 33:       String configPath =  realPath + "webconfig.ini";
> Line 34:       MapGuideApi.MgInitializeWebTier(configPath);
> Line 35:   }
> Line 36:
> Line 37:   // Searches the map for a layer with the specified name.
> Line 38:
> Line 39:   MgLayer GetLayerByName(MgMap map, String layerName)
> Line 40:   {
> Line 41:       MgLayer layer = null;
> Line 42:       for (int i = 0; i < map.GetLayers().GetCount(); i++)
> Line 43:       {
> Line 44:           MgLayer nextLayer = map.GetLayers().GetItem(i);
> Line 45:           if (nextLayer.GetName() == layerName)
> Line 46:           {
> Line 47:               layer = nextLayer;
> Line 48:               break;
> Line 49:           }
> Line 50:       }
> Line 51:       return layer;
> Line 52:   }
> Line 53:
> Line 54:   // Read the content from an MgByteReader and send it back as the response.
> Line 55:   void OutputReaderContent(MgByteReader byteReader, HttpResponse response)
> Line 56:   {
> Line 57:       MemoryStream memBuf = new MemoryStream();
> Line 58:
> Line 59:       byte[] byteBuffer = new byte[1024];
> Line 60:       int numBytes = byteReader.Read(byteBuffer, 1024);
> Line 61:       while(numBytes > 0)
> Line 62:       {
> Line 63:           memBuf.Write(byteBuffer, 0, numBytes);
> Line 64:           numBytes = byteReader.Read(byteBuffer, 1024);
> Line 65:       }
> Line 66:
> Line 67:       response.ContentType = byteReader.GetMimeType();
> Line 68:       byte [] content = memBuf.ToArray();
> Line 69:       response.OutputStream.Write(content , 0, content.Length);
> Line 70:   }
> Line 71:
> Line 72:   </script>
> Line 73:
> *Version Information:* Microsoft .NET Framework Version:2.0.50727.42;
> ASP.NET <http://asp.net/> Version:2.0.50727.42
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060704/b80cd8c3/attachment.html
More information about the Mapguide_users mailing list
