Tool Tip issue...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jul 5 15:07:11 EDT 2006
I've got a field with a space in the name that I'd like to have in the
tool tip. Studio doesn't seem to like that. Is there a trick that will
make it work? I've tried putting the field name between square brackets,
in double quotes, etc. What's the proper syntax? Or does it just not
work if you've got a space?
Andrew
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
