[mapguide-users] I can't see views when I use the FDO/ODBC.
Andy Morsell
amorsell at spatialgis.com
Wed Jul 5 17:53:12 EDT 2006
A view is a query definition within the Access database itself. There are
several types of views, but in this case, it would be a select view where
either a single table is filtered or two or more tables are joined on a
common key. Views are very common. They are called Queries in SQL Server
and Views in Oracle.
Andy
-----Original Message-----
From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
Sent: Wednesday, July 05, 2006 2:47 PM
Subject: Re: [mapguide-users] I can't see views when I use the FDO/ODBC.
What exactly are you trying to look for other than a table? What's a 'view'?
Do you mean a 'form'? ODBC connections will only let you access tables. No
forms, no reports, etc....
Andrew
Luiz Marcio Viana wrote:
> Hi,
> I'm trying to see views in MapGuide Studio, using the FDO/ODBC, but I
> see only the tables.
> I'm using the MS Access database and the last versions of MapGuide
> Open Source and MapGuide Studio Preview.
> Are there any problem with FDO/ODBC to publish views?
> I know FDO/ODBC works only with MS Access. Is It right?
> Thanks,
> Luiz Marcio
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
