[mapguide-users] Exporting as XML
Bill Dhimitri bill.dhimitri at autodesk.com
Fri Jul 7 10:04:51 EDT 2006
Can you give some more details on this?  What part/element of the layer
XML failed to validate?  How did you create the layer XML?
MG Studio has a "File | Save As XML" menu item that will create a layer
XML file. So if you have MG Studio, you might try creating the layer XML
file and seeing if it validates.
Bill
-----Original Message-----
Sent: Thursday, July 06, 2006 11:29 PM
Subject: [mapguide-users] Exporting as XML
The MG OS Dev Guide suggests that you can save a layer as XML and then
add it
to the map (page 67 ff). I saved some of the sample layers( parcels and
newbuildings). However, these XML files don't validate against the XSD
for
layers, LayerDefinition-1.0.0.xsd. Is this going to be fixed, or are
developers expected to make their own XML that validates against the
XSD?
That would be a painful process.
View this message in context:
http://www.nabble.com/Exporting-as-XML-tf1904164.html#a5211030
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
