Fatal parse error
newjim
j_oleary_ed at yahoo.ca
Fri Jul 7 10:52:48 EDT 2006
I am working through the Adding Layers to a Map section of the Dev Guide
(page 67 ff). I have made an XML file from the parcels layer, which passes
the validation test in this line in the example code:
$domDocument->schemaValidate(
"$schemaDirectory\LayerDefinition-1.0.0.xsd
It also executes the following lines with success:
$byteSource = new MgByteSource($layerDefinition,
strlen($layerDefinition));
$byteSource->SetMimeType(MgMimeType::Xml);
$resourceID = new MgResourceIdentifier(
"Session:$mgSessionId//$layerName.LayerDefinition");
However, it crashes at this line:
$resourceService->SetResource($resourceID,
$byteSource->GetReader(), null);
...with the error message:
An exception occurred in DB XML component. Error: XML Indexer: Fatal Parse
error in document at line, 1, char 1. Parser message: Invalid document
structureAn exception occurred in DB XML component. Error: XML Indexer:
Fatal Parse error in document at line, 1, char 1. Parser message: Invalid
document structure Exception occurred in method
MgResourceDefinitionManager.ValidateDocument at line 431 in file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
Any suggestions? I'm stumped.
Thanks
View this message in context: http://www.nabble.com/Fatal-parse-error-tf1906921.html#a5218822
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users
