[mapguide-users] RE: Exporting as XML
Ben Trumbore ben.trumbore at autodesk.com
Fri Jul 7 14:28:52 EDT 2006
I think that the ">" in this filter may be causing the problem.  There
are five characters that must be "escaped"
<http://www.w3schools.com/xml/xml_cdata.asp>  when included in a layer's
XML (", ', &, < and >) to allow for proper parsing.  In this case, your
filter line should be:
      <Filter>YRBUILT &gt; 1950</Filter>
When a programmatically created layer model is serialized, this escaping
is peformed as part of the process.  If you create the XML directly, you
need to do it explicitly.
Ben
-----Original Message-----
Sent: Friday, July 07, 2006 10:57 AM
Subject: [mapguide-users] RE: Exporting as XML
I studied the LayerDefinition-1.0.0.xsd schema and realized that I had
put
the <Filter>YRBUILT > 1950</Filter> line in the Dev Guide example in the
wrong place. I got it to validate, but now it crashes with a parse
error.
Please see the next posting about this posting.
View this message in context:
http://www.nabble.com/Exporting-as-XML-tf1904164.html#a5218898
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060707/8ff66a09/attachment.html
More information about the Mapguide_users mailing list
