Exporting as XML
newjim
j_oleary_ed at yahoo.ca
Fri Jul 7 15:26:18 EDT 2006
That is a good trick, but the program still crashes. However, there is a
complete example in the new deb guide documentation, and it does not crash,
so i will look at that. Here is the XML in that sample, named
RecentlyBuilt.LayerDefinition
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd" version="1.0.0">
<VectorLayerDefinition>
<ResourceId>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</ResourceId>
<FeatureName>SHP_Schema:Parcels</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
<PropertyMapping>
<Name>NAME</Name>
<Value>NAME</Value>
</PropertyMapping>
<PropertyMapping>
<Name>ID</Name>
<Value>ID</Value>
</PropertyMapping>
<PropertyMapping>
<Name>YRBUILT</Name>
<Value>YRBUILT</Value>
</PropertyMapping>
<Geometry>SHPGEOM</Geometry>
<VectorScaleRange>
<MaxScale>10000</MaxScale>
<AreaTypeStyle>
<AreaRule>
<LegendLabel>Built after 1950</LegendLabel>
<Filter>YRBUILT > 1950</Filter>
<Label>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
<SizeX>0.3</SizeX>
<SizeY>10</SizeY>
<Text>YRBUILT</Text>
<FontName>Arial</FontName>
<ForegroundColor>FF000000</ForegroundColor>
<BackgroundColor>FFFFFFFF</BackgroundColor>
<BackgroundStyle>Transparent</BackgroundStyle>
<HorizontalAlignment>'Center'</HorizontalAlignment>
<VerticalAlignment>'Baseline'</VerticalAlignment>
</Label>
<AreaSymbolization2D>
<Fill>
<FillPattern>Solid</FillPattern>
<ForegroundColor>FFFFFF00</ForegroundColor>
<BackgroundColor>FF000000</BackgroundColor>
</Fill>
<Stroke>
<LineStyle>Solid</LineStyle>
<Thickness>0</Thickness>
<Color>FF000000</Color>
<Unit>Inches</Unit>
</Stroke>
</AreaSymbolization2D>
</AreaRule>
</AreaTypeStyle>
</VectorScaleRange>
</VectorLayerDefinition>
</LayerDefinition>
View this message in context: http://www.nabble.com/Exporting-as-XML-tf1904164.html#a5223231
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users
