[mapguide-users] WMS and MapGuide Enterprise 2007 problem
Paul Ramsey
pramsey at refractions.net
Sun Jul 9 21:14:41 EDT 2006
Andy,
Save the result and open it up in a notepad. The text of the return
may indicate where the problem is. The whole "download" issue is a
side-effect of the OGC decision to specify their own MIME-types (why?
why?! why?!!) for the XML error returns in WMS (instead of just using
text/xml like good puppies). Your browser sees a MIME-type it
doesn't understand, cannot find a handler for it, and falls back on
the only remaining option, save it to disk. But it's just a text XML
chunk, I bet, and if your lucky it even describes your error
condition in a helpful way.
Paul
On 9-Jul-06, at 12:04 PM, Andy Morsell wrote:
> Hi,
> I got MapGuide Enterprise 2007 installed and running on my
> development box yesterday (XP Pro and IIS 5, .NET web extensions)
> and only ran into a couple of snags. I am still re-configuring
> everything to work with the new version and the biggest problem I
> have run into is WMS requests not working. Whenever a standard WMS
> request is made (such as http://localhost/mapguide/mapagent/
> mapagent.fcgi?request=GetMap&service=WMS&layers=Samples/Sheboygan/
> Layers/Hydrography&srs=EPSG:
> 4326&bbox=-87.74,43.68,-87.69,43.815&width=500&height=500&format=image
> /png) I am prompted with a browser File Download dialog to download
> mapagent.fcgi. Actually, the same thing happens with a non-WMS
> MapGuide GetMap request. Thanks to Thomas Tuerke for providing the
> HTML page to test this stuff a few days ago.
> WMS appears to be configured in Admin and I changed the default
> server name of localhost:8008 to localhost (by the way, Autodesk,
> saving WMS parameters from Admin does not work in IE 7 beta, I had
> to use Firefox). Also, the layers are properly exposed to WMS via
> Studio. The only difference I can see between this configuration
> and my older MGOS install on my production server is that the WMS
> server name still says (provide your server name), but it still
> works. I am able to successfully get WMS capabilities via http://
> localhost/mapguide/mapagent/mapagent.fcgi?
> REQUEST=GetCapabilities&SERVICE=WMS&FORMAT=text/xml and everything
> looks fine there. This problem almost looks like a mime type
> issue, but I am able to make the same calls to my older system and
> it returns an image.
> So, any ideas why the request is not returning an image?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
More information about the Mapguide_users
