findparcelfunctions.aspx
newjim
j_oleary_ed at yahoo.ca
Tue Jul 11 19:25:19 EDT 2006
I am still having a problem with this, although I've done the procedure that
Jason suggested and replaced the ll84Wkt line with:
$ll84Wkt =
'PROJCS["NAD83/98.MTM-10",GEOGCS["LL-CSRS",DATUM["CSRS",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",304800.000],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999900000000],PARAMETER["central_meridian",-79.50000000000000],PARAMETER["latitude_of_origin",0.00000000000000],UNIT["Meter",1.00000000000000]]';
...which is the coordinate system I'm using.
I'm able to stick pins on the Sheboygan map with the default string in the
sample. However, no pin shows on my Saturna map. Any suggestions?
View this message in context: http://www.nabble.com/findparcelfunctions.aspx-tf1400459.html#a5280003
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users
