[mapguide-users] more linux compile errors than you can shake a stick at
    Traian Stanev
    traian.stanev at autodesk.com
    Thu Jul 13 08:37:19 EDT 2006
Hi Mark,
The libtool errors may be due to mismatched versions of your local
automake version and the version in the MapGuide subversion. Did you try
recreating libtool by running libtoolize, aclocal and automake/autoconf?
Traian
  _____
Sent: Wednesday, July 12, 2006 11:16 PM
To: users
Subject: [mapguide-users] more linux compile errors than you can shake a
stick at
Hello,
I checked out revision 715 today and continued to try to complete the
build on SuSE linux with gcc 4.1
The build is still problematic in a number of areas, below is a list of
some examples of the errors one encounters when compiling on linux. I
assume that most of you are developing your apps on the Windows
platform?
- ACE libraries in the OEM do not compile without editing some of the
source.
- There are a number of tags that libtool doesn't support:
libtool: unrecognized option `--tag=CXX'
- The MdfModel compile in the common directory produces a number of
errors like this one:
GridSurfaceStyle.h:77: error: explicit instantiation of 'class
std::auto_ptr<MdfModel::GridSurfaceStyle>' in namespace 'MdfModel'
(which does not enclose namespace 'std')
- A number of extra qualifications persist, for example:
./Services/PrintLayout.h:216: error: extra qualification
'MgPrintLayout::' on member 'LegendWidth'
./Services/PrintLayout.h:217: error: extra qualification
'MgPrintLayout::' on member 'LegendPadding'
./Services/PrintLayout.h:218: error: extra qualification
'MgPrintLayout::' on member 'HeaderHeight'
./Services/PrintLayout.h:219: error: extra qualification
'MgPrintLayout::' on member 'ScalebarHeight'
./Services/PrintLayout.h:220: error: extra qualification
'MgPrintLayout::' on member 'ScalebarPadding'
./Services/PrintLayout.h:221: error: extra qualification
'MgPrintLayout::' on member 'FooterHeight'
./Services/PrintLayout.h:222: error: extra qualification
'MgPrintLayout::' on member 'GroupIndent'
(and in MgDev/Oem/geos-2.2.0/source/headers/geos/geos.h, as well as a
dozen other header files)
- The library libgeos.a is not compiled with the build_oem.sh script, so
you have to enter that dir to compile, and then continue with the main
mapguide make
- libtool: unrecognized option `---mode=link'
 in Makefile /home/mark/DEV_FORK/mapguide/MgDev/Web/src/JavaApi/Makefile
This is by no means a complete list but hopefully provides an indication
of the current state of the Makefiles in the revisions...
Mark
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060713/af34c751/attachment.html
More information about the Mapguide_users
