[mapguide-users] OBDC - testing connection
Robert Fortin
robert.fortin at autodesk.com
Fri Jul 14 11:43:28 EDT 2006
Ivan,
One developer suggested to alter the config to use comma instead of dot. like the following:
<gml:boundingBox>
<gml:pos>1234567,000000 1234567,000000</gml:pos>
</gml:boundingBox>
The failure seems to occur somewhere in the code parsing that info and it gets one parameters when it should see 2. It might related to your language setup.
RF
_____
Sent: Friday, July 14, 2006 11:39 AM
Subject: RE: [mapguide-users] OBDC - testing connection
Ok,
Thanks!
_____
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: 14. srpanj 2006 17:37
And I'm not in a position to do that either. Maybe someone else on the list has done a recent compile for Windows and can provide a link.
Sorry,
Dave
_____
Sent: Friday, July 14, 2006 9:32 AM
Hi Dave,
It would be possible but i can't compile source code, don't ask why, simply i can't. Could you do that for me? Please. Just send me a link and i will reisntall or unistall server.
Thanx a lot!
Ivan
_____
Sent: 14. srpanj 2006 17:24
I can't seem to find anything wrong with the config information when I compare it to a working instance I have.
I suspect this is an issue with the 168.02 version. We did have some problems that were fixed in regards to ODBC after that build. Would it be possible to try this with a build of the current source?
Dave
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060714/3424df71/attachment.html
More information about the Mapguide_users
