Compatibility between Autodesk Mapguide Enterprise 2007 and Autodesk Map 3d 2007
Chris White chris.white at keytraffic.com
Mon Jul 17 09:50:33 EDT 2006
I have installed Mapguide Enterprise 2007 onto a machine that also has Map installed, and although I can't be sure that the 2 event are linked, Map now does not load correctly (giving a C:\Program Files\Autodesk Map 3D 2007\AcMapWorkspace.arx cannot find a procedure that it needs.
.Failed.
AcMapWorkspace.arx Load Failed Error). I've tried both a repair and full uninstall/install of Map and still no luck.
Are there any know issues with running the two together?
Thanks in advance,
Chris
Chris White
Software Architect
Key Traffic Systems Ltd.
Ardencroft Court
Ardens Grafton
Alcester
Warwickshire
B49 6DP
Main: +44(0)8451 303040
Fax: +44(0)8451 303141
Mailto: chris.white at keytraffic.com <mailto:%20chris.white at keytraffic.com>
Web: www.keytraffic.com <http://www.keytraffic.com/> 	 	This e-mail & any attachments are intended only for the use of the person(s) to whom it is addressed. It may contain information that is privileged and confidential within the meaning of applicable law. If you are not the intended recipient, please contact the sender as soon as possible by return mail or Tel +44 (0) 8451 303040. The views expressed in this communication may not necessarily be the views held by Key Traffic Systems Ltd.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060717/7337a7d6/attachment.html
More information about the Mapguide_users mailing list
