[mapguide-users] MapGuide on Fedora Core 5
Marcus Spurkel mspurkel at pacbell.net
Tue Jul 18 03:34:30 EDT 2006
Thanks Traian.
I've made good progress (I think): Got MapGuide to compile & install and
I have successfully built FastCGI, which was also a challenge in Apache
2.2.  Since I already have Apache installed, I went through the build
script and applied the settings manually.  I thought I was ready to try
the mapagent.fcgi test from the "Building and Configuring on Linux" PDF,
but alas, the server returns a 500 error.  Just for fun, I tried running
it from a command prompt on the server and got the following message:
./mapagent?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&RESOURCEID=Library://
[1] 18444
[2] 18445
-bash: ./mapagent?OPERATION=ENUMERATERESOURCES: No such file or directory
"No such file or directory"?  Does that mean I don't have something
configured right?  Is this an obvious error to you?  A little help would
be greatly appreciated.
-Marcus
Traian Stanev wrote:
>Hi Marcus.
>The highest gcc we have tried so far is 4.0.2. The "extra qualification" stuff we've already fixed. Only the -pedantic setting in gcc would throw that error before 4.1, and we didn't use that so that's why we didn't catch it.
>Your solution to the template instantiation is also correct. Removing it shouldn't hurt as far as I know. We'll take care of that too.
>Please let us know if you have more problems (at least the ones related to MapGuide, hehe).
>Traian
>	-----Original Message-----
>	From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
>	Sent: Mon 7/17/2006 4:51 PM
>	To: users at mapguide.osgeo.org
>	Cc:
>	Subject: [mapguide-users] MapGuide on Fedora Core 5
>	Okay, I may be completely out of my mind here (as well as new to this
>	project so I probably just don't know any better <g>) but I'm trying to
>	compile MapGuide on my Fedora Core 5 server with gcc 4.1.1.
>	Having a devil of a time.  It basically boils down to running make,
>	waiting for it to bomb out and then looking at and hopefully fixing the
>	error.
>	And there are lots of 'em!  Most of the complaints were of the "extra
>	qualification..." variety so I just deleted the offending qualifier.  I
>	also ran into the "explicit instantiation of non-template type..." error
>	in ChannelBand.h.  The best solution I've found so far was to comment
>	out the line entirely -- it doesn't seem to hurt the compilation.  The
>	new gcc seems to be a lot less forgiving than the version that MapGuide
>	is normally compiled with (3.4?)  This may be a fool's quest.
>	But I _did_ finally get it to compile!
>	I'm running "make check" right now (so far, so good -- it's an old
>	machine so it'll take a while) and looking forward to seeing if it will
>	actually work...
>	Has anyone else had any experience with MapGuide on a new system?
>	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>	For additional commands, e-mail: users-help at mapguide.osgeo.org
>No virus found in this incoming message.
>Checked by AVG Free Edition.
>Version: 7.1.394 / Virus Database: 268.10.1/390 - Release Date: 7/17/2006
More information about the Mapguide_users mailing list
