MapGuide Service Stops after sometime.
Sajith S sajith at kalkitech.com
Thu Jul 20 00:19:29 EDT 2006
I am new to MapGuide Open Source Server.
I setup the mapGuide Server in a windows 2000 Prof. environment with Ajax
viewer.
The sample provided along with the mapguide ,Sheboygan is working fine.
Now i am creating my own application using Autodesk Mapguide Studio 2007
Preview
MapGuide Server version is 1.0.0.16407
Now i am facing some problems, i created the my own application which uses
SHP files.
Now the Ajax Viewer displays the Map etc. But after sometime after 10-15
minutes Mapguide Server Service pop-up some error which is getting logged in
the event logger. After this error my application stops working if i stop
and start the service then it starts again.
Error shown in the System log of event viewer is given below.
Application popup: MgServer.exe - Application Error : The instruction at
"0x00fcfd2e" referenced memory at "0x00000000". The memory could not be
"read".
thanks
Sajith S
More information about the Mapguide_users mailing list
