mapguide.fcgi gets "Segmentation fault" error
Marcus Spurkel
mspurkel at pacbell.net
Fri Jul 21 16:36:45 EDT 2006
I'm still struggling with my mapguide installation on FC5. After
finally getting it to compile, I run the mgserver.sh script and
everything seems to come up okay:
# ps aux | grep mgserver
root 15279 0.0 0.1 4404 1016 pts/3 S+ 13:07 0:00 /bin/sh
server/bin/mgserver.sh
root 15280 0.2 6.3 385292 32644 pts/3 Sl+ 13:07 0:03
./mgserver /interactive
But when I try to run the mapguide.fcgi test (as per the "Building and
Configuring on Linux" guide)
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&RESOURCEID=Library://
the server hangs and finally comes back with a 500 internal error.
The Apache logs reveal the following:
[Fri Jul 21 13:08:36 2006] [warn] FastCGI: (dynamic) server
"/usr/local/mapguideopensource/webserverextensions/www/mapagent/mapagent.fcgi"
(pid 15345) terminated due to uncaught signal '11' (Segmentation fault)
has failed to remain running for 30 seconds given 3 attempts, its
restart interval has been backed off to 600 seconds
I know FastCGI works because I tested it with another program. Is there
a way to test mapagent outside the context of a web app to perhaps get
some more helpful info?
-Marcus
More information about the Mapguide_users
