[mapguide-users] App stops working after a few uses
kenny at keniginc.com
Mon Jul 24 14:46:35 EDT 2006
This happens mostly when I attempt to load a few shp files using the
studio or when attemping to set the correct map extent; still
struggling to get the correct map view extent. It is mostly alright.
I suppose the process is performance intensive.
Please confirm that this will work. I am a bit too careful giving that
this server runs some other applications.
pskill MapGuide Server
For those of you who may have used this, please that this command will
work, and only for the mapguide server.
Thanks for the quick response
Quoting Andrew DeMerchant <andrew.demerchant at gemtec.ca>:
> If you want to force a service to stop, then try kill.exe (comes with
> the resource kit), or pskill.exe (from sysinternals.com)....that will
> let you stop a service that's not cooperating....though, in the end,
> you'll want to figure out what is causing the problem....
> kenny at keniginc.com wrote:
>> Not sure if anyone has had to deal with the current issue I am having.
>> I reboot our server at least 4 times a day.
>> I do this because after running the map app for about 3 times, it
>> stops loading and hangs.
>> When I try stopping and restarting service, service hangs on
>> "stopping" until I reboot the server.
>> I am very concerned about having to constantly reboot the server,
>> especially since we have other apps running on the server.
>> Is there a way to restart the service or the app without having to
>> reboot the server?
>> My boss is scheduled to do a demo of the os app 3:30pm today and I
>> have been testing it just to be sure all is well.
>> After my last test, now it is hung again.
>> Please assist.
>> Thanks
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
More information about the Mapguide_users
