[mapguide-users] App stops working after a few uses
kenny at keniginc.com
Mon Jul 24 15:07:45 EDT 2006
That worked like a dream.
Now, I wouldn't have to reboot anymore.
Thanks Andy, James, and Andrew; Andy special thanks for providing the script.
Quoting Andy Morsell <amorsell at spatialgis.com>:
> This is also in that older thread, but here are the contents of the batch
> file that I use:
> c:\pskill mgserver
> c:\psservice stop "MapGuide Server"
> c:\psservice start "MapGuide Server"
> echo MapGuide restarted %date% %time% "<br>" >>
> c:\inetpub\wwwroot\restart_MapGuide_log.htm
> The psservice stop is a bit redundant, but I figured it couldn't
> hurt........ The logging stuff is obviously optional.
> Andy
> -----Original Message-----
> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
> Sent: Monday, July 24, 2006 11:47 AM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] App stops working after a few uses
> This happens mostly when I attempt to load a few shp files using the studio
> or when attemping to set the correct map extent; still struggling to get the
> correct map view extent. It is mostly alright.
> I suppose the process is performance intensive.
> Please confirm that this will work. I am a bit too careful giving that this
> server runs some other applications.
> pskill MapGuide Server
> For those of you who may have used this, please that this command will work,
> and only for the mapguide server.
> Thanks for the quick response
> Quoting Andrew DeMerchant <andrew.demerchant at gemtec.ca>:
>> If you want to force a service to stop, then try kill.exe (comes with
>> the resource kit), or pskill.exe (from sysinternals.com)....that will
>> let you stop a service that's not cooperating....though, in the end,
>> you'll want to figure out what is causing the problem....
>> kenny at keniginc.com wrote:
>>> Not sure if anyone has had to deal with the current issue I am having.
>>> I reboot our server at least 4 times a day.
>>> I do this because after running the map app for about 3 times, it
>>> stops loading and hangs.
>>> When I try stopping and restarting service, service hangs on
>>> "stopping" until I reboot the server.
>>> I am very concerned about having to constantly reboot the server,
>>> especially since we have other apps running on the server.
>>> Is there a way to restart the service or the app without having to
>>> reboot the server?
>>> My boss is scheduled to do a demo of the os app 3:30pm today and I
>>> have been testing it just to be sure all is well.
>>> After my last test, now it is hung again.
>>> Please assist.
>>> Thanks
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-4GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
More information about the Mapguide_users
