[mapguide-users] Some Help with Raster!!!
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Jul 25 15:23:31 EDT 2006
Did you also add those files (for the FDO) to your Studio FDO folder?
Assuming that you installed it correctly, you could just copy your FDO
folder from MapGuide overtop of the one in Studio....but I'd make a
backup of the Studio copy first!
Andrew
Arq. Luis E. Marin M. wrote:
> Yes I install the raster fdo but when put those files in my directory
> of map guide the layers previously created by me disappear !!! and the
> error with the rasters still here!!! Im very confused!
> CEO
> Simbiosis Group Inc.
> +58-2129432453 CCS
> +58-4166050203 CCS
> +01-3109283934 USA
> *****REGULACIÓN DE USO DEL CORREO ELECTRÓNICO DE Simbiosis Group Inc.
> HACIA INTERNET*****
> La información contenida en este correo electrónico y cualquier anexo
> puede ser de carácter confidencial y es propiedad de Simbiosis Group
> Inc. Sólo está permitido su uso, copia, transmisión, recepción o
> distribución a personas debidamente autorizadas. Si usted recibió este
> correo por error por favor destrúyalo y/o elimine cualquier copia
> guardada en su sistema y notifique inmediatamente al remitente o a la
> dirección de correo electrónica info at simbiosisgroup.net
> <mailto:info at simbiosisgroup.net>. Usted no debe utilizar la
> información contenida para ningún propósito ni compartirla con otras
> personas.
> This e-mail, including any attached files, may contain confidential
> and privileged information for the sole use of the Simbiosis Group
> Inc. Any review, use, distribution, or disclosure by others is
> strictly prohibited. If you are not the intended recipient (or
> authorized to receive information for the intended recipient), please
> contact the sender by reply info at simbiosisgroup.net
> <mailto:info at simbiosisgroup.net> and delete all copies of this message.
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Tuesday, July 25, 2006 3:13 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Some Help with Raster!!!
> Did you install the Raster FDO
> (https://mapguide.osgeo.org/files/documents/12/76/Raster.zip)?
> I need put some raster behind of my actual map I successful created my
> layers but y cat load the rasters because a error that say " server
> does not support requested provider: autodesk.raster" and I cant load
> my rasters any can helpme please!!! I very cuffused!!!
> Many thanks and sorry about my english
> CEO
> +58-2129432453 CCS
> +58-4166050203 CCS
> +01-3109283934 USA
> HACIA INTERNET*****
> personas.
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
