[mapguide-users] configure parameters for PHP 5.1.4?
Marcus Spurkel mspurkel at pacbell.net
Thu Jul 27 02:59:46 EDT 2006
I'll see if I can get you a list tomorrow.  In the meantime, Trevor
Wekel gave me the tip that got everything working for me at last.  Just
a few strategically placed "#ifndef PHPPROXYAPI_EXPORTS" in php.h and
everything fell into place.  I now have MapGuide running on my FC5 box
with gcc 4.1, Apache 2.2 and PHP 5.1.4.  Nice!
BTW, would you use Fedora as a production server OS for MapGuide, or
would you recommend RedHat Enterprise instead?
-Marcus
Traian Stanev wrote:
>Most of the extra qualification errors are in the FDO headers, which are in a separate svn vault (fdo.osgeo.org). I know there are several template errors in the MdfModel project of MapGuide that haven't been checked in yet, like in ChannelBand.h. I'll take care of those. If you want to send us the files that you think need to be fixed, that would be cool too...
>Traian
>	-----Original Message-----
>	From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
>	Sent: Wed 7/26/2006 6:17 PM
>	To: users at mapguide.osgeo.org
>	Cc:
>	Subject: Re: [mapguide-users] configure parameters for PHP 5.1.4?
>	Ah -- that would explain it, yes.  I was beginning to think the same
>	thing.  Knowing that that _is_ in fact the case, maybe I can figure it
>	out on my own but by all means take a look at let me know what it was
>	that you changed.
>	While we're on the subject, are the other changes to the mapguide
>	files,such as the "extra qualification" errors going to get published?
>	Last time I checked the svn tree, I didn't see any evidence of that.
>	Thanks again,
>	-Marcus
>	>Oooh, yeah, I forgot that I hacked two or three PHP headers to make it compile with 5.1.4. I will go back and track down the changes tomorrow, since I didn't actually keep track the first time around... However, the changes necessary for Linux may be different than the ones for Windows, but we'll see I guess.
>	>My theory at the time was that definitions in PHP 5.1.4 headers are conflicting with libACE headers.
>	>Traian
>	>       Sent: Wed 7/26/2006 4:37 PM
>	>       Cc:
>	>       Subject: [mapguide-users] configure parameters for PHP 5.1.4?
>	>       I'm still struggling with getting PhpApi to compile for PHP 5.1.4  It
>	>       comes back with conflicting declaration errors.  Here's what I've done:
>	>       1. unpack the latest tarball from php.net (5.1.4) to mapguide-1.0.0/Oem
>	>       2. rename the existing php dir (5.0.5 I believe) to php_old
>	>       3. rename the new php--xxx dir to "php" so it matches the old layout
>	>       4. cd php and run ./configure
>	>       5. go to Web/src/PhpApi and try "make clean" and "make"
>	>       ../../../Oem/php/regex/regex.h:17: error: conflicting declaration
>	>       'typedef off_t regoff_t'
>	>       /usr/include/regex.h:419: error: 'regoff_t' has a previous declaration
>	>       as 'typedef int regoff_t'
>	>       ...and so on
>	>       What's interesting is that when I swap the original php directory back
>	>       in (php -> php_new and php_old -> php) the re-make for PhpApi works just
>	>       fine so I'm thinking it's got something to do with one or more files in
>	>       the two PHP dirs.  Specifically, it seems to complain about regex a
>	>       lot,  but the regex.h files in Oem/php/regex are identical between 5.0.5
>	>       and 5.1.4.  Can someone tell me how the php dir was "prepped" to work
>	>       within the context of MapGuide so I can duplicate it with 5.1.4?  Any
>	>       specific ./configure parameters that I need to provide or directories
>	>       that I need to change/prune?
>	>       Much appreciated,
>	>       -Marcus
>	>       To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>	>       For additional commands, e-mail: users-help at mapguide.osgeo.org
>	>No virus found in this incoming message.
>	>Checked by AVG Free Edition.
>	>Version: 7.1.394 / Virus Database: 268.10.4/399 - Release Date: 7/25/2006
More information about the Mapguide_users mailing list
