[mapguide-users] MapGuide Open Source Web Studio
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jul 27 09:05:02 EDT 2006
Got it...thanks Zak. I was hoping that it was going to help me make
PrintLayouts (since Studio is pretty lame for that), or would let me
save Maps, but it looks like neither one are in there yet......looks
like it's going to rock once it's done though!
Zak James wrote:
>> ... in a trunk of the mapguide svn...
> Uh, I guess that should be branch... :)
> zak
> On 7/26/06, Zak James <zak4ms at gmail.com> wrote:
>> Andrew,
>> Webstudio is in a trunk of the mapguide svn. You can get it with a
>> command like:
>> svn checkout
>> https://mapguide.osgeo.org/svn/mapguide/branches/1.0.x/MgDev/Web/src/webstudio/
>> webstudio_svn --username <osgeo-username>
>> It should run out of the box against any 1.0.0+ server, assuming you
>> put it in a web accessible directory and your machine has php 4.4 or
>> better installed.
>> zak
>> Zak James
>> Applications and Software Development
>> DM Solutions Group Inc.
>> http://www.dmsolutions.ca
>> On 7/26/06, Andrew DeMerchant <andrew.demerchant at gemtec.ca> wrote:
>> >  Is this still being developed? Is it available for download yet
>> (even in
>> > beta form)?
>> >  Andrew
>> >  Paul Spencer wrote:
>> > ok, I think I get it.  I'll have to try this.  This will actually
>> help me
>> > test the code that enumerates the feature classes in an fdo
>> feature source
>> > (I didn't have any data to test more than one feature  class so I
>> bet it
>> > will fail ;))
>> >  Cheers
>> >  Paul
>> >  On 5-Jun-06, at 10:50 PM, Robert Bray wrote:
>> > Paul,
>> >  Using local references as in my previous e-mail you do not need
>> to  call
>> > SetResourceData at all. With SHP just reference a directory  like
>> this:
>> >  <?xml version="1.0" encoding="utf-8" ?>
>> >  <FeatureSource
>> > xmlns:xsi="http://www.w3.org/2001/XMLSchema- instance"
>> > xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> > xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>> >  <Provider>OSGeo.SHP.3.0</Provider>
>> >  <Parameter>
>> >  <Name>DefaultFileLocation</Name>
>> >  <Value>C:\MyData</Value>
>> >  </Parameter>
>> >  </FeatureSource>
>> >  MapGuide will automatically expose each SHP file in the C:\MyData
>> folder
>> > as a Feature Class. Just make sure each SHP file has a PRJ  file that
>> > MapGuide supports via Proj.4 and you are all set. Note  that Studio
>> will not
>> > show the SHP files in the Feature Source  editor, but that does not
>> mean
>> > anything in this case. Studio is  just showing the result of
>> enumerating the
>> > data associated with the  resource (e.g. being managed by that
>> resource). In
>> > this case you  are managing the data, not MapGuide so it shows
>> nothing.
>> >  FYI - I seem to recall a bug with the SHP FDO Provider where all
>> of  the
>> > data in a directory needs to use the same projection, so you  might
>> want to
>> > watch out for that.
>> >  Bob
>> >  -----Original Message-----
>> >  From: Paul Spencer (External)
>> >  Sent: Mon 6/5/2006 10:13 PM
>> >  To: users at mapguide.osgeo.org
>> >  Cc:
>> >  Subject: Re: [mapguide-users] MapGuide Open Source Web Studio
>> >  ahhh ... thats the trick.
>> >  When I looked at an uploaded shape file using GetResourceContents
>> >  <?xml version="1.0" encoding="utf-8"?>
>> >  <FeatureSource
>> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> >     <Parameter>
>> >       <Value>%MG_DATA_FILE_PATH%</Value>
>> >     </Parameter>
>> >  </FeatureSource>
>> >  it didn't seem to list the actual files so I wasn't sure what I could
>> >  do with this and SetResourceContent.  Using EnumerateResourceData
>> >  listed the actual files but there didn't seem to be a way to put this
>> >  XML back into the server.   Now that I look at the schema for the
>> >  feature source, I realize that I could probably just have multiple
>> >  Parameter tags, one for each file, and used SetResourceContent :)
>> >  Cheers
>> >  Paul
>> >  On 5-Jun-06, at 9:48 PM, Robert Bray wrote:
>> >  > Paul,
>> >  > A typical FeatureSourceDefintion (for SDF) that is created by
>> >  > Studio looks like:
>> >  > <FeatureSource
>> >  > instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> >  > <Provider>OSGeo.SDF.3.0</Provider>
>> >  > <Parameter>
>> >  > <Name>File</Name>
>> >  > <Value>%MG_DATA_FILE_PATH%Parcels.sdf</Value>
>> >  > </Parameter>
>> >  > <Parameter>
>> >  > <Name>ReadOnly</Name>
>> >  > <Value>TRUE</Value>
>> >  > </Parameter>
>> >  > </FeatureSource>
>> >  > If you replace the %MG_DATA_FILE_PATH% with a physical path to the
>> >  > file on the servers file system you can effectively "reference"
>> >  > data and not worry about uploading it. A similar technique can be
>> >  > used for SHP files, Raster files, etc.
>> >  > Bob
>> >  > Sent: Mon 6/5/2006 9:14 PM
>> >  > Cc:
>> >  > The preview of the web layout is from the sample Sheboygan package.
>> >  > Web Studio can load web layouts using the ajax viewer, you just
>> can't
>> >  > create or edit them yet.
>> >  > I had originally thought that we would only be supporting data that
>> >  > was already on the server.  The data that is stored on the
>> server is
>> >  > reported through the MapAgent using the EnumerateResourceData
>> >  > operation.  The XML returned from this lists the data file or files
>> >  > that are part of the resource.  There doesn't seem to be a way to
>> >  > create the XML and put it into the server.  Thus it doesn't seem
>> >  > possible to support creating a feature source that refers to data
>> >  > already on the server.  I could be wrong about this, though.
>> >  > Cheers
>> >  > Paul
>> >  > On 5-Jun-06, at 6:20 PM, Jason Birch wrote:
>> >  > > IANAP (I am not a Paul), but I think that "The primary goal
>> of  this
>> >  > > release is to enable users to get data into the server" must mean
>> >  > > that there is some mechanism for either uploading data, or (based
>> >  > > on some questions Paul asked on this list) possibly referring to
>> >  > > data that is already on the server.
>> >  > > One of the screen shots shows a web layout.  Perhaps there is a
>> >  > > "default" web layout provided?
>> >  > > Jason
>> >  > > ________________________________
>> >  > > From: Andy Morsell [@spatialgis.com]
>> >  > > Sent: Mon 2006-06-05 2:44 PM
>> >  > > Subject: RE: [mapguide-users] MapGuide Open Source Web Studio
>> >  > > Wow, that really does look great.  I'm confused on a couple of
>> >  > issues,
>> >  > > though.  First, it doesn't support load procedures, etc.  I think
>> >  > > that makes
>> >  > > sense for a pure web-based authoring tool, but at this point,
>> >  > > people will
>> >  > > still have to use MapGuide Studio to load their data and then
>> >  > > author it with
>> >  > > this tool instead?  I could see that a company may choose to
>> have a
>> >  > > couple
>> >  > > of licenses of Studio for this and other advanced functionality
>> >  > > purposes and
>> >  > > then use the open source version for other folks needing to
>> create
>> >  > > maps from
>> >  > > that data.  I also imagine that others will eventually
>> develop  open
>> >  > > source
>> >  > > tools for loading data without the need for Studio.
>> >  > > Second, you say that it doesn't support web layouts.  Are the
>> >  > > webLayout's in
>> >  > > the Web Studio version different than MapGuide Studio web
>> layouts?
>> >  > > Thanks again for developing this open source tool.  It will
>> be  very
>> >  > > useful.
>> >  > > <winmail.dat>
>> >  > > To unsubscribe, e-mail:
>> > users-unsubscribe at mapguide.osgeo.org
>> >  > > For additional commands, e-mail: users-help at mapguide.osgeo.org
>> >  > |Paul Spencer
>> > pspencer at dmsolutions.ca   |
>> >  > |Applications & Software
>> > Development                              |
>> >  > |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
>> >  |Paul Spencer
>> > Development                              |
>> >  |Paul Spencer
>> > Development                              |
>> >  Andrew DeMerchant
>> >  Computer Technologist
>> >  ph.1-877-4GEMTEC x.163
>> >  fax 506-453-9470
>> > GEMTEC Limited
>> >  191 Doak Road
>> >  Fredericton, NB, Canada
>> >  E3C 2E6
	*Andrew DeMerchant*
*Computer Technologist*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
