Installing MapGuide Web Extensions in alternate location (IIS Installation)
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jul 27 19:19:47 EDT 2006
In case anyone else is interested in installing the Web Extensions in an
alternate location (IIS Installation), the following changes need to be
made:
* Install package
- Specify custom installation and change installation path for each of
the packages
* File Locations
- Even after changing the install directory in the installer, most
files will be placed in the default location. Move these manually to
the new location
* PHP.INI file
- Change the extension dir setting to the correct location
* mapguide/webconfig.ini file
- Change the ResourcesPath setting to the new location
* Environment Variables
- Alter the values of GDAL_DATA and PROJ_LIB.
- I also added the PHP directory to the path; not sure if this is
required
* Registry
- Alter the location of the MapAgent.exe and PHP-CGI.exe paths stored
in the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI
* IIS
- Change the location of the following virtual directories:
- mapguide
- mapguide/mapagent
- mapguide/mapviewerajax
- mapguide/mapviewerdwf
- Change the following application configuration paths
- mapguide application: remap the setting for .php to the new
location for the FCGI ISAPI dll
- mapguide/mapagent application: remap the setting for .fcgi to the
new location for the FCGI ISAPI dll
- (IIS6 Only) Change location of files in Web Service Extensions to
match their new location
There are a couple points in there where you may need to stop/restart
IIS to unlock files or make it reregister ISAPI settings.
You'll probably also want to change your webstudio/config.xml file to
point to your site.
I think that's everything that I did. If you follow these instructions
and are still having problems, please post here; I may just have missed
a step.
It would be great if the installation package for both the Web
Extensions and Server allowed installation in an alternate location
seamlessly.
Jason
More information about the Mapguide_users
