[mapguide-users] Is everbody on holiday or something?
    Nattavut.S at samtel.samartcorp.com
    Fri Jul 28 05:20:44 EDT 2006
I have the same problem, and would appreciate any assistance on this one.
I even try to use Feature joint to link geometry information from a SHP
file, but that also results in a lot of crash in the Studio.  It would be
great if anyone could point me to the proper way of adding Geometry into
the mysql database or linking between entries in the database and Geometry
from SHP file?
Thanks,
Natt
  _____
Sent: Thursday, July 27, 2006 8:35 PM
Subject: RE: [mapguide-users] Is everbody on holiday or something?
Hi Traian,
You are correct, Dave Wilson had the same answer. I'm now trying to use
myODBC, but I'm having problems with that too. Please read my previous
post about this..
Thanks,
Willem
  _____
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: donderdag 27 juli 2006 15:17
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Is everbody on holiday or something?
I am not sure about the answer to this so someone should correct me if I'm
wrong... I think only the ODBC provider will let you specify separate
columns for x and y and then will treat that as a point. All other
providers expect the data to have a bona fide geometry property. The x and
y columns in your case are just simple data attributes, and not geometry.
Traian
  _____
Sent: Tuesday, July 25, 2006 9:36 AM
Importance: High
Here is what I see in studio when connecting to mysql through Mapserver
Enterprise 2007.
There are X and Y columns, but why can't I choose a geometry? I just want
to create a point layer from a database source, just like I did on windows
with the odbc FDO.
Willem
  _____
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: Tuesday, July 25, 2006 3:26 PM
I tried the one that comes with mysql and now I can connect. But in the
list of data stores there is nothing. I'm trying to create one no to check
differences.
Willem
  _____
Verzonden: Tuesday, July 25, 2006 3:15 PM
Does it need to be a specific version? Because I tried one that was
installed with PHP5, but that one gave errors. Another gave also errors.
Willem
  _____
Verzonden: Tuesday, July 25, 2006 3:09 PM
You need to copy libmysql.dll to the directory where the provider dll is,
likely under /FDO/bin relative from where acad.exe is located. Autodesk
can't legally distribute MySQL binaries, hence you have to download it
yourself. This should be documented somewhere in the Map documentation.
Traian
  _____
Sent: Tuesday, July 25, 2006 9:04 AM
Subject: [mapguide-users] Is everbody on holiday or something?
Where is the feedback? Is Autodesk still reading this list?
The MySQL provider does not give me geometry. I have exported the access
database to mysql.
Also could not test connection in Map 2007 because libmysql.dll was not
found?!
Willem
     This email service is provided for business use only. Any information retained is considered Samart property. Samart preserves its rights to randomly scan mail content for any misuse.
     This email is confidential, may be legally privileged, and is for the intended recipient only. Disclosure, copying, distribution, or reliance on any of it by anyone else is prohibited and may be a  criminal offence. Please delete if obtained in error and email confirmation to the sender.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060728/59c55d4f/attachment.html
More information about the Mapguide_users
