[mapguide-users] Printing to specific scale doesn't work - wrong scale
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Jul 28 18:10:58 EDT 2006
Thanks for entering the OSGeo artifact (#341).  A defect has to also be
submitted against DWF Viewer, which I'll do.  I'll include a reference
to the artifact.
Walt
-----Original Message-----
From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
Sent: Friday, July 28, 2006 5:58 PM
Subject: Re: [mapguide-users] Printing to specific scale doesn't work -
wrong scale
Walt...I'm seeing this problem in the DWF Viewer....and I suspect, like
you suggest, that this is only in the DWF Viewer. Sounds like you got
the same results as I did....I've  already submitted this as a defect
(yesterday), so there's no need for you to do it, though the info on
your other tests would likely help out.
Andrew
Walt Welton-Lair wrote:
> Andrew,
> Are you seeing this behavior with AJAX or DWF viewer (or both)?
> I did a quick experiment with DWF Viewer using the Sheboygan sample
> data and the "Plot at Specified Scale" functionality.  The on-screen
> EPlot preview that was generated seems to have the correct scale (I
> measured by hand and assumed 8.5" page width, so screen resolution
> wasn't a factor).  I plotted to a scale of 8000, and the scale I
> computed was 8080.  Some of that error I attribute to my on-screen
> measurements.  When I printed the DWF though (at 100%) and measured
> the scale from the printout I got 8350, so a little over 4% error.  I
> estimated my on-paper measurement error to be about 20 units.
> It's possible there's some inaccuracy in the printing code.  To test
> this, I first printed the DWF to an MDI file using the MSO Live
> Meeting Document Writer Driver, and then used MSO Document Imaging to
> print the MDI.  In this case, the scale on paper correctly came to
8000.
> So my conclusion, at least for DWF Viewer, is that there's a printing
> bug which is causing this inaccuracy.  I'll submit a defect for this.
> Walt
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Thursday, July 27, 2006 2:22 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Printing to specific scale doesn't
> work - wrong scale
> I had it backwards....to print something out so that it's ACTUALLY at
> 1:10000, you have to fiddle with it until it's around 1:9375...then
> you can use a 1:10000 scale to measure things correctly. Hope that
> illustrates the problem........still no rasters being printed either!
> Andrew
> Andrew DeMerchant wrote:
>> Nope....nothing quite so simple unfortunately......also of note, I
>> just tried to print the same thing out at 1:10666 (which should equal
>> 1:10000, if I did my math right), but that just plain doesn't
>> work...I get a blank page. I'm guessing that you can't just type in
>> the scale that you want, unless it's in the list (though the program
>> lets you think that you can do it)
>> Andrew
>> Andy Morsell wrote:
>>> You don't have any printer specific override settings that might be
>>> affecting this do you?  Such as a "scale page to fit" or similar
option?
>>> Andy
>>> *Sent:* Thursday, July 27, 2006 10:46 AM
>>> *Subject:* [mapguide-users] Printing to specific scale doesn't work
>>> - wrong scale
>>> If you select a printout to be at a specific scale, it's wrong (off
>>> by about 5%).
>>> If you are using a custom print layout with a scalebar, it's easier
>>> to notice right away. Print something at 1:10000, for example. Then
>>> grab an actual 1:10000 scale and you'll see that the scale bar on
>>> the page is too small. From 0 to 600 metres, it should measure 60mm,
>>> but is actually only 56mm. This translates to a 40metre error when
>>> scaling things off of the printout. The scalebar does actually match
>>> the scale of the drawing though, but it is not 1:10000, as it
claims.
>>> Has anyone run into this? I've just submitted it as a bug....maybe
>>> there's a workaround though....
>>> Andrew
>>> 	*Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-4GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>> 	*Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
