[mapguide-users] Custom Command Error
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jun 1 03:25:25 EDT 2006
I don't have access right now, but I believe that the plot layout that comes as a default uses the symbol library to reference custom logos and the like. You may need to edit your plot layout to get rid of these references?
Jason
Sent: Wed 2006-05-31 3:39 PM
Subject: [mapguide-users] Custom Command Error
I have updated the plottask.php and plot.php script to reflect the map
being plotted. The plot tool window appears in the right column when
the tool is selected, however when the user clicks on either plot
button contained in the tool window the following error appears:
Resource was not found:
Library://FolderName/MySymbolLibrary.SymbolLibrary
Library://FolderName/MySymbolLibrary.SymbolLibrary Exception occurred
in method MgResourceDefinitionManager.GetDocument at line 483 in file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionM
anager.cpp
I am not using a symbol library... does anyone know how I can remove
this error?
Thanks,
Joy.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060601/bdab6f1b/attachment.bin
More information about the Mapguide_users
