[mapguide-users] Petitions too slow?
Andy Morsell
amorsell at spatialgis.com
Thu Jun 1 12:06:59 EDT 2006
Hi Jose,
I'm curious how you got the object Properties to appear programmatically
after selecting the object? I have some similar functionality and when I
select the object programmatically (using MGSelection.AddFeatureID), it is
only highlighted on the map with the Properties pane empty.
Thank you.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
From: Jose Manuel C G [mailto:gis at mapas-sll.com]
Sent: Thursday, June 01, 2006 7:57 AM
Subject: Re: [mapguide-users] Petitions too slow?
Here is the modified code in php, the basic is here, the rest you can
imagine...
<?php
include 'appconstants.php'; //In this file I've included the code to
$siteConnection, $resourceService and $featureService.
$matches = 0;
$StrAddr = trim($_GET['StrAddr']);
$NumVia = trim($_GET['HouseNumber']);
if (strlen($owner) > 0){
if (strlen($NumVia) > 0){
$filter = "NOMBREVIA LIKE '" . $StrAddr . "'
AND PRIMERNUM = " . $NumVia . "";
$featureResId = new
MgResourceIdentifier("Library://<path to your
FSource>/Callejero.FeatureSource");
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetFilter($filter);
$geometryReaderWriter = new
MgAgfReaderWriter();
$featureReader =
$featureService->SelectFeatures($featureResId,
"Callejero", $queryOptions); // Callejero is the name of the layer
while ($featureReader->ReadNext()){
$name =
$featureReader->GetString('NOMBREVIA');
$tipovia =
$featureReader->GetString('TIPOVIA');
$refcat =
$featureReader->GetString('CRT');
$byteReader =
$featureReader->GetGeometry('Geometry');
$geometry =
$geometryReaderWriter->Read($byteReader);
$point = $geometry->GetCentroid();
$x =
$point->GetCoordinate()->GetX();
$y =
$point->GetCoordinate()->GetY();
echo "setArrayElement(' $tipovia
$name, $NumVia ');";
$matches++;
}else{
// If the user only input Street Name
$featureResId = new
FSource>/Calles.FeatureSource");
$featureReader =
"Calles", $queryOptions); //Calles is the name of another layer
$idc =
$featureReader->GetString('IDC');
$tipovia =
$name =
$escala =
$featureReader->GetString('ESC');
$byteReader =
$geometry =
$x =
$y =
$name ');";
$matches++;
$featureReader->Close();
}else{
// The user doesn't input a Street Name
echo "traducir('Bsq03');"; // traducir is a function in
javascript to translate.
if ($matches == 0){
echo "traducir('Bsq04');";
View this message in context:
http://www.nabble.com/Petitions+too+slow--t1715911.html#a4663663
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
