Problem with rasters
barns05
temp at barnay.org
Thu Jun 1 12:41:26 EDT 2006
I can't post rasters with MapGuide Open source.
When I import tiff or ECW with the provider raster, no image is visible in
the layer preview and the file “error.log” gives me the following message:
<2006-06-01T18:30:31>
Error: An exception occurred in FDO component.
Failed to de-serialize the spatial contexts from the configuration.
StackTrace:
- MgOpGeneratePlot.Execute line 96 file
c:\build_tux_area\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures line 633 file
c:\build_tux_area\mgdev\server\src\services\rendering\ServerRenderingService.cpp
- MgServerGetSpatialContexts.GetSpatialContexts line 109 file
c:\build_tux_area\mgdev\server\src\services\feature\ServerGetSpatialContexts.cpp
- MgFdoConnectionManager.Open line 263 file
c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cppAn
If somebody has a solution…
Thank you very much,
Frederic
View this message in context: http://www.nabble.com/Problem+with+rasters-t1717837.html#a4665414
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users
