AW: [mapguide-users] Use ODBC data for tool tip
Thomas Grosser
grosser at kom21.de
Fri Jun 2 06:59:05 EDT 2006
Dear Dave,
Thanks for the answer and the small tutorial. I got it combined (when Server and Studio is on the same machine), but I didn´t get any tooltip and could not select any item ...
Any ideas ?
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
-----Ursprüngliche Nachricht-----
Von: Dave Wilson [mailto:dave.wilson at autodesk.com]
Gesendet: Donnerstag, 1. Juni 2006 16:32
An: users at mapguide.osgeo.org
Betreff: RE: [mapguide-users] Use ODBC data for tool tip
Hi Thomas,
on your datasource for your layer you need to execute a join.
The primary column is for the key column from your datasource that matches a key in your odbc datasource. The secondary column is the join key from your ODBC database.
When building your layer you need to select the extended feature class name from your join. If the layer is already built you will need to reselect the datasource to populate the drop down. Otherwise build a new layer.
When selecting the geometry use the original geometry from your datasource, do not use the new geometry from the join.
You should see the new columns from your odbc datasource appear in the layer properties. Change the Display name if you like.
You should then be able to use the new columns in the tooltip expression.
Regards,
Dave
-----Original Message-----
Sent: Thursday, June 01, 2006 7:00 AM
Subject: [mapguide-users] Use ODBC data for tool tip
we are trying to get the data out of a joined ODBC database for showing them as a tooltip ... Is there any documentation or any tip available ?
Thomas Grosser
Kom21 - Nürnberg
90419 Nürnberg
Web: www.kom21.de
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
