[mapguide-users] Add/Modify Feature Data
Jason Birch Jason.Birch at nanaimo.ca
Mon Jun 5 10:45:53 EDT 2006
Absolutely :)
For the first question, the FeatureService provides the functions that you need, and for the second, the ResourceService.
The Web API docs provide information on these areas:
https://mapguide.osgeo.org/nonav/docs/webapi/index.html <https://mapguide.osgeo.org/nonav/docs/webapi/index.html>
You will also want to explore the various API functions; most of them are available through
http://localhost:8008/mapguide/mapagent/index.html <http://localhost:8008/mapguide/mapagent/index.html>   (Apache) or
http://localhost/mapguide/mapagent/index.html <http://localhost/mapguide/mapagent/index.html>  (IIS)
Also, the developer's guide provides some guidance in these areas:
https://mapguide.osgeo.org/docs/MgOpenSourceDevGuide.pdf <https://mapguide.osgeo.org/docs/MgOpenSourceDevGuide.pdf>
... and I answered parts of this question recently under the subject "how to draw a polygon and save it?"
http://www.nabble.com/RE%3A--mapguide-dev--how-to-draw-a-polygon-and-save-it--p4616125.html <http://www.nabble.com/RE%3A--mapguide-dev--how-to-draw-a-polygon-and-save-it--p4616125.html>
Jason
Subject: [mapguide-users] Add/Modify Feature Data
Hello,
1. Is it possible to add/modify feature data from the front end i.e. .NET or
PHP
2. Would it be possible to modify the theme i.e. UI of a layer from the
front end ?
Kalpesh
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060605/2b279b11/attachment.bin
More information about the Mapguide_users mailing list
