[mapguide-users] MapGuide Open Source Web Studio
Robert Bray
robert.bray at autodesk.com
Mon Jun 5 21:48:23 EDT 2006
Paul,
A typical FeatureSourceDefintion (for SDF) that is created by Studio looks like:
<?xml version="1.0" encoding="utf-8" ?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SDF.3.0</Provider>
<Parameter>
<Name>File</Name>
<Value>%MG_DATA_FILE_PATH%Parcels.sdf</Value>
</Parameter>
<Parameter>
<Name>ReadOnly</Name>
<Value>TRUE</Value>
</Parameter>
</FeatureSource>
If you replace the %MG_DATA_FILE_PATH% with a physical path to the file on the servers file system you can effectively "reference" data and not worry about uploading it. A similar technique can be used for SHP files, Raster files, etc.
Bob
-----Original Message-----
Sent: Mon 6/5/2006 9:14 PM
Cc:
Subject: Re: [mapguide-users] MapGuide Open Source Web Studio
The preview of the web layout is from the sample Sheboygan package.
Web Studio can load web layouts using the ajax viewer, you just can't
create or edit them yet.
I had originally thought that we would only be supporting data that
was already on the server. The data that is stored on the server is
reported through the MapAgent using the EnumerateResourceData
operation. The XML returned from this lists the data file or files
that are part of the resource. There doesn't seem to be a way to
create the XML and put it into the server. Thus it doesn't seem
possible to support creating a feature source that refers to data
already on the server. I could be wrong about this, though.
Cheers
Paul
On 5-Jun-06, at 6:20 PM, Jason Birch wrote:
> IANAP (I am not a Paul), but I think that "The primary goal of this
> release is to enable users to get data into the server" must mean
> that there is some mechanism for either uploading data, or (based
> on some questions Paul asked on this list) possibly referring to
> data that is already on the server.
> One of the screen shots shows a web layout. Perhaps there is a
> "default" web layout provided?
> Jason
> ________________________________
> From: Andy Morsell [@spatialgis.com]
> Sent: Mon 2006-06-05 2:44 PM
> Subject: RE: [mapguide-users] MapGuide Open Source Web Studio
> Wow, that really does look great. I'm confused on a couple of issues,
> though. First, it doesn't support load procedures, etc. I think
> that makes
> sense for a pure web-based authoring tool, but at this point,
> people will
> still have to use MapGuide Studio to load their data and then
> author it with
> this tool instead? I could see that a company may choose to have a
> couple
> of licenses of Studio for this and other advanced functionality
> purposes and
> then use the open source version for other folks needing to create
> maps from
> that data. I also imagine that others will eventually develop open
> source
> tools for loading data without the need for Studio.
> Second, you say that it doesn't support web layouts. Are the
> webLayout's in
> the Web Studio version different than MapGuide Studio web layouts?
> Thanks again for developing this open source tool. It will be very
> useful.
> <winmail.dat>
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060605/222f1761/attachment.html
More information about the Mapguide_users
