[mapguide-users] select objects on multiple layers
Willem Schwarte willem at giskit.nl
Tue Jun 6 10:06:56 EDT 2006
Ok, sorry, I think I have got it... changed code to this:
                        $filter = "CRE03 = '00000030UP-BBW' AND
(HYPERLINK = 's199' OR HYPERLINK = 's132')";
$opts = new MgFeatureQueryOptions();
                        $opts->SetFilter($filter);
$sel = new MgSelection($map);
                        $layers = $map->GetLayers();
                        for ($i = 0; $i < $layers->GetCount(); $i++)
                                   $firstLoop = 1;
                                   $layer = $layers->GetItem($i);
                                    if ($layer)
                                               $featureClassName =
$layer->GetFeatureClassName();
                                               $srcId = new
MgResourceIdentifier($layer->GetFeatureSourceId());
                                               $features =
$featureService->SelectFeatures($srcId, $featureClassName, $opts);
                                               $hasResult =
$features->ReadNext();
                                               if($hasResult)
                                                              do
$sel->AddFeatureIdInt32($layer, $featureClassName,
$features->GetInt32('FeatId'));
while($features->ReadNext());
                                               }else
echo "no results";
                                   } // endif
                        } // next $i
$selText = StrEscape($sel->ToXml(), true);
<a href="#" onClick="CellClicked('<?=$selText;?>');">Click to select
objects</a>
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: dinsdag 6 juni 2006 15:53
Aan: users at mapguide.osgeo.org
Onderwerp: [mapguide-users] select objects on multiple layers
Hi ,
I now use this code to generate a link with xml to select objects found
on the layers in a map:
                                   $firstLoop = 1;
                                    if ($layer)
                                               $featureClassName =
                                               $srcId = new
                                               $features =
                                               $hasResult =
                                               if($hasResult)
                                                              $sel = new
MgSelection($map);
                                                              do
objects</a>
                                               }else
echo "no results";
                                   } // endif
                        } // next $i
Now I will e.g. get 2 links. What I really want to achieve is that 1 XML
string is created so if I click on the link, all objects on all layers
will be selected.
Is this at all possible?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060606/b4eca133/attachment.html
More information about the Mapguide_users mailing list
