[mapguide-users] aclocal - warning on Fedora ...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Jun 9 07:52:53 EDT 2006
They are warnings - you can ignore them.
_____
From: Mandar Sarlashkar [mailto:mann.sar at gmail.com]
Sent: Friday, June 09, 2006 5:48 AM
Subject: [mapguide-users] aclocal - warning on Fedora ...
I am settingup Mapguide OpenSource on Fedora...
I am getting following warning after I run # aclocal
[root at localhost mapguide-1.0.0]# aclocal
acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
run info '(automake)Extending aclocal'
or see
http://sources.redhat.com/automake/automake.html#Extending-aclocal
acinclude.m4:12: warning: underquoted definition of MAP_SUBST
acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
acinclude.m4:25: warning: underquoted definition of MAP_GEN_CONFIG_VARS
acinclude.m4:67: warning: underquoted definition of
MAP_GENERATE_MAKEFILES
acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
acinclude.m4:83: warning: underquoted definition of
MAP_DEFINE_TYPE_RLIM_T
acinclude.m4:108: warning: underquoted definition of
MAP_SUBST_EXPANDED_ARG
acinclude.m4:115: warning: underquoted definition of
MAP_EXPORT_ARGUMENTS
Can anybody Please explain me ....What am I expected to do... ?
Thanks in advance...
Mandy
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060609/bad09a67/attachment.html
More information about the Mapguide_users
