[mapguide-users] Create Layer
Amit Stein amitstein at gmail.com
Tue Jun 13 10:16:45 EDT 2006
Bob,
I used Data because in Map Guide Studio the Geometry field said ¨Data¨.
What else can it be?
Amit
On 6/13/06, Robert Bray <robert.bray at autodesk.com> wrote:
>  Amit,
> In the sample code "Data" is the name of the geometry column in the SDF
> file. Your SDF file may use a different name to refer to the geometry
> property. One way to determine the name is to create a layer based on that
> SDF in Studio and see what Studio puts in the "Geometry:" field.
> Bob
> *From:* Amit Stein [mailto:amitstein at gmail.com]
> *Sent:* Monday, June 12, 2006 10:31 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] Create Layer
> Hi everybody,
> I used the functions from layerdefinitionfactory.php to create a layer and
> the functions from the Developer's Guide (page 59) to add a layer. I had
> trouble creating and adding a layer to a map. None of the stuff I've been
> trying worked.
> The Feauture Source I am using is a SDF file and the type of geometry is
> Data. I used the Data type because in Map Guide Studio worked. However, I am
> not sure if this is what I am supposed to use when programmatically creating
> layers.
> I suppose that what I am doing is correct, but I can´t see the results.
> When I run the script the layer does not show up in the map. Maybe the layer
> was created but it wasn't added. Does anybody know how I can fix this???
> I attached here the code. If somebody needs the SDF, ask me (I don´t send
> it because it weights 3MB).
> Thank you
> Amit
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060613/9da19ca2/attachment.html
More information about the Mapguide_users mailing list
