make check hangs... Cannot Establish Connection
Mandar Sarlashkar
mann.sar at gmail.com
Wed Jun 14 07:24:58 EDT 2006
Dear Traian Stanev and Walt Welton-lair !
I really appreciate the support I am getting from you...
Traian Stanev, Thank you very much for the Makefile.am....
Now I have one more problem to bother you... and other Members of the list
as well... I hope you wont mind....
When I ran
# Make Check
The process hangs... and after waiting for a long time I have to Interrupt
by pressing Ctl C....
Below is the text copied from Command Prompt
When process hangs....
make[4]: Entering directory `/usr/local/mapguide-1.0.0/Server/src/Core'
GDAL_DATA=/usr/local/mapguide-1.0.0/Oem/gdal-1.3.0/data
PROJ_LIB=/usr/local/mapguide-1.0.0/Oem/proj-4.4.9/nad
After I Interrupt....
make[4]: *** [check-TESTS] Interrupt
make[3]: *** [check-am] Interrupt
make[2]: *** [check-recursive] Interrupt
make[1]: *** [check-recursive] Interrupt
make: *** [check-recursive] Interrupt
I shouldn't have proceeded... but just to check what happens I ran
# make install
and when I tested following URL I got the following error message
displayed in the browser...
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&RESOURCEID=Library://
Cannot establish connection. Cannot establish connection. Exception occurred
in method MgServerConnection.Open at line 94 in file
Services/ServerConnection.cpp - MgHttpRequest::CreateRequestResponseHandler
line 271 file HttpRequest.cpp -
MgHttpRequestResponseHandler.InitializeCommonParameters line 133 file
HttpRequestResponseHandler.cpp - MgSite.Open line 93 file Services/Site.cpp
- MgSite.Authenticate line 1244 file Services/Site.cpp -
MgServerConnection.Open line 94 file Services/ServerConnection.cpp
I really want to setup and see my Maps on web through Mapguide
OpenSource... and needs help...
Thanks in advance...
Mandy
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060614/798ed659/attachment.html
More information about the Mapguide_users
