No database connection via FDO/ODBC
Stefan.Reuschel at dataprocess.de Stefan.Reuschel at dataprocess.de
Fri Jun 16 09:01:36 EDT 2006
Hi all,
until now I was not successful in connecting to a simple local Access database via the most recent downloadable FDO provider for ODBC connections. Generally it shouldn't be impossible, since once or twice I got a successfully established connection.
I'm successfully testing an "out of the box" MapGuide OS 1.0.0 (bundled, with Apache/PHP/Tomcat) and MapGuide Studio preview 2007, both together installed on 1. w2k Server (SP4) or 2. XP (SP1).
Previews, Layout management etc. work (mostly) fine so far, but as soon as I try to test the connection (either connection string or data source name), I permanently receive the previously mentioned error:
         "System.Net.WebException: The remote server returned an error: (559) MgFdoException. at ..."
Only the "Refine data setup" is activated, allowing me to specify the geometry columns.
The mgserver.exe process keeps the database locked, even if MapGuide Studio is shut down. The process has to be killed first, and then the lockfile *.mdl has to be deleted manually before any further access to the db is possible. Restarting or introducing "new" system databases did not help. What else?
Does anyone have any suggestions? (Or do we have a "raster-provider-like" problem? ;-)
Thanks in advance!
> Stefan Reuschel
> IT Consultant Informationssysteme
data process GmbH
Ludwig-Erhard-Straße 6
34131 Kassel
Tel: +49 (0)561 9301-1439  Fax: +49 (0)561 9301-1894
Email: stefan.reuschel at dataprocess.de
www.dataprocess.de
data process GmbH
> Ludwig-Erhard-Str. 6
> 34131 Kassel
> Geschäftsführer: Dr. Ulrich Lamp
> Sitz der Gesellschaft: Kassel
> Handelsregister: Kassel HRB 7103
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060616/68e3df94/attachment.html
More information about the Mapguide_users mailing list
