[mapguide-users] Mapguide dotnetsampleviewer problem
Dennis Megarry
dennis at myairplane.com
Fri Jun 23 19:03:02 EDT 2006
Thanks for the infor, but in my email I listed that it was started and then
I tried starting it in interactive mode as well with no changes to my
problem.. :(
Dennis
----- Original Message -----
To: <users at mapguide.osgeo.org>
Sent: Friday, June 23, 2006 3:54 PM
Subject: Re: [mapguide-users] Mapguide dotnetsampleviewer problem
Dennis,
I had similar problem when I setup my MG OS last week.
The only way I was able to solve that problem is by taking following steps:
1. Open the Windows "Control Panel"
2. Select the "Administrative Tools" entry
3. Launch the "Services" panel
4. Status for ?MapGuide Server? should be ?Started?. If not, right
click on the "MapGuide Server" item and select "Start"
I researched the forum to find this solution.
Hopefully, it works for you too.
Quoting Dennis Megarry <dennis at myairplane.com>:
> I've setup Mapguide on a Windows 2003 box, installed the sample data and
> setup everything correctly (as far as I know), when I try to run the
sample
> ajax viewer, I get:
> "Cannot establish connection.Cannot establish connection. Exception
occurred
> in method MgServerConnection.Open at line 94 in file
> c:\build_tux_area\mgdev\common\service\services\ServerConnection.cpp :
> I stopped the mapguide service and started it in interactive mode, but
> nothing appears in the dos window.. Anyone run into this before?
> Dennis
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
