OSGeo FDO problem...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jun 28 09:23:44 EDT 2006
It seems that the OSGeo FDO provider doesn't like spaces in table names.
The error log said that the FDO was causing a "Syntax error in FROM
clause". Is this something that can be fixed? It should be a pretty
simple fix, really..since I'd guess that all that needs to be done is to
enclose table names (and field names, for that matter) in square
brackets (ie, [Table Name], or [Table Name].[Field Name]). The work
around for me for now is to make another Access database and link all of
the tables from my real database. In this new database, I just rename
the tables to get rid of the spaces. But I can't really rely on his
workaround, because having to change table names means changing a lot of
other things for other projects (this database is used in a lot of other
ways, not just MapGuide). Is there any chance that this FDO can get
modified to account for these spaces?
Andrew
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
