[mapguide-users] OSGeo FDO problem...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jun 28 10:41:00 EDT 2006
No filter...
Traian Stanev wrote:
> Hmm. It could be that the provider is being careless with filter
> conversion to string. Do you have a filter set on the layer, or are
> you simply trying to preview the whole layer with no filter?
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Wednesday, June 28, 2006 9:59 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] OSGeo FDO problem...
> I'd love to try that, but where do I have that option? I'm using
> Studio...I see no place to either use an SQL statement of my own, or
> to put anything (let alone quotes) around a table name.
> Andrew
> Robert Fortin wrote:
>> Andrew,
>> Have you tried using single quote around you table name/column?
>> RF
>> *Sent:* Wednesday, June 28, 2006 9:24 AM
>> *Subject:* [mapguide-users] OSGeo FDO problem...
>> It seems that the OSGeo FDO provider doesn't like spaces in table
>> names. The error log said that the FDO was causing a "Syntax error in
>> FROM clause". Is this something that can be fixed? It should be a
>> pretty simple fix, really..since I'd guess that all that needs to be
>> done is to enclose table names (and field names, for that matter) in
>> square brackets (ie, [Table Name], or [Table Name].[Field Name]). The
>> work around for me for now is to make another Access database and
>> link all of the tables from my real database. In this new database, I
>> just rename the tables to get rid of the spaces. But I can't really
>> rely on his workaround, because having to change table names means
>> changing a lot of other things for other projects (this database is
>> used in a lot of other ways, not just MapGuide). Is there any chance
>> that this FDO can get modified to account for these spaces?
>> Andrew
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-4GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
