[mapguide-users] Layer Groupings, Andy can you help?
Andy Morsell
amorsell at spatialgis.com
Thu Jun 29 21:00:02 EDT 2006
I used Snagit to grab the screenshot, copy to the clipboard and then paste
to the Outlook email. That was probably the problem. Here it is attached
as a JPG file instead.
Andy
-----Original Message-----
From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
Sent: Thursday, June 29, 2006 5:33 PM
Subject: Re: [mapguide-users] Layer Groupings, Andy can you help?
It's in that winmail.dat file....he must be using Outlook, and you must not
be (neither am I). Check out this page for the solution:
http://www.gpc.edu/~jbenson/resource/winmail.htm
Making those themed layers really isn't too complex though. I'd offer you
some help right now, but I'm home for the night, and don't have Studio in
front of me.
Andrew
kenny at keniginc.com wrote:
> Thanks a lot, Andy.
> I am going over the gettingStarted pdf file as I write this.
> Visually, it would have been great to see the attachment you
> mentioned. It apparently didn't come through.
> Quoting Andy Morsell <amorsell at spatialgis.com>:
>> Those are standard thematic layers created in Studio when defining
>> the layer style. Attached is a screenshot. There is also an example
>> in the GettingStartedGuide.pdf that is in the Studio Help folder.
>> You can also open and examine in Studio the Parcels layer definition,
>> which is themed, in your Sheboygan sample dataset.
>> Andy
>> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
>> Sent: Thursday, June 29, 2006 1:27 PM
>> Subject: [mapguide-users] Layer Groupings, Andy can you help?
>> Andy, I see you that you get picked on a lot around here for obvious
>> reasons. Sorry for joining that group.
>> Reason, I am singled you out is I saw on your sampe MG OS app that
>> you grouped Roads into Major and Minor categories.
>> Did you do this programmatically or did you do it through the Studio?
>> Obviously, for me at this stage, I would prefer to do things through
>> the studio until I am very knowledgeable about the architecture.
>> From what I have read, you use themes to accomplish this but how do
>> I do this?
>> For instance, I have basins that need to be grouped into several sub
>> layers, each with same view extent.
>> Any assistance, including any materials that would make this easy.
>> Thanks for getting me started on MG OS.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060629/1f046df4/themed_layer.jpg
More information about the Mapguide_users
