[mapguide-users] Layer Groupings, Andy can you help?
kenny at keniginc.com kenny at keniginc.com
Fri Jun 30 10:14:55 EDT 2006
ouch, I can't find the response I got from Jason.
Guys, can any of you guys give me likely scenarios why I could not
find a screen similar to the screenshot attached by Andy?
According to Jason Birch, it is supposed to be to the far of the
screenshot I attached.
On that screen, I see Add a scale Range, Duplicate, Delete, Move Up,
and Move Down arrows, nothing else.
Further down, I see, 0 - Infinity: Area, or point or line
Last line at the bottom says: Style of Geometry and Feature Label.
Could there be any possible reason why I can't see a Theme button?
Quoting Andy Morsell <amorsell at spatialgis.com>:
> I used Snagit to grab the screenshot, copy to the clipboard and then paste
> to the Outlook email.  That was probably the problem.  Here it is attached
> as a JPG file instead.
> Andy
> -----Original Message-----
> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> Sent: Thursday, June 29, 2006 5:33 PM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] Layer Groupings, Andy can you help?
> It's in that winmail.dat file....he must be using Outlook, and you must not
> be (neither am I). Check out this page for the solution:
> http://www.gpc.edu/~jbenson/resource/winmail.htm
> Making those themed layers really isn't too complex though. I'd offer you
> some help right now, but I'm home for the night, and don't have Studio in
> front of me.
> Andrew
> kenny at keniginc.com wrote:
>> Thanks a lot, Andy.
>> I am going over the gettingStarted pdf file as I write this.
>> Visually, it would have been great to see the attachment you
>> mentioned. It apparently didn't come through.
>>> Those are standard thematic layers created in Studio when defining
>>> the layer style.  Attached is a screenshot.  There is also an example
>>> in the GettingStartedGuide.pdf that is in the Studio Help folder.
>>> You can also open and examine in Studio the Parcels layer definition,
>>> which is themed, in your Sheboygan sample dataset.
>>> Andy
>>> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
>>> Sent: Thursday, June 29, 2006 1:27 PM
>>> Subject: [mapguide-users] Layer Groupings, Andy can you help?
>>> Andy, I see you that you get picked on a lot around here for obvious
>>> reasons. Sorry for joining that group.
>>> Reason, I am singled you out is I saw on your sampe MG OS app that
>>> you grouped Roads into Major and Minor categories.
>>> Did you do this programmatically or did you do it through the Studio?
>>> Obviously, for me at this stage, I would prefer to do things through
>>> the studio until I am very knowledgeable about the architecture.
>>>  From what I have read, you use themes to accomplish this but how do
>>> I do this?
>>> For instance, I have basins that need to be grouped into several sub
>>> layers, each with same view extent.
>>> Any assistance, including any materials that would make this easy.
>>> Thanks for getting me started on MG OS.
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
