[mapguide-users] Using Symbols strange behaviour
Ben Trumbore ben.trumbore at autodesk.com
Fri Jun 30 12:08:18 EDT 2006
Willem,
I believe that you are seeing known defects in the preview release, and
there is no workaround for them at this time.  Numerous improvements
have been made to point style rendering since the preview release.  I
just tested these cases using the upcoming release and non-default
reference points, rotations, and png transparency all worked as
expected.
                Ben
  _____
Sent: Friday, June 30, 2006 5:46 AM
Subject: [mapguide-users] Using Symbols strange behaviour
I am trying to use symbols (png) but it does not quite work as I would
like it to.
The normal.jpg is the map with symbols loaded normal, but when I change
the reference point in studio, the symbol stays at the same spot?
If I use a rotation angle (rotated.jpg) the symbol gets a black colored
part in it?
When importing rijdende-afzetting3.png in symbol library, the
transparency is lost? Is this not supported?
Code_b.png is the original picture.
Willem
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060630/ed05b2c2/attachment.html
More information about the Mapguide_users mailing list
