[mapguide-users] RE: problems with new release
"Antonio Lucas Rodríguez (sr&tec)"
alucas at srtec.com
Wed Mar 8 03:22:03 EST 2006
Hartesh Chhabra wrote:
> Hi,
> Please see responses inline-
> *From:* "Antonio Lucas Rodríguez (sr&tec)" [mailto:alucas at srtec.com]
> *Sent:* Tuesday, March 07, 2006 8:15 AM
> *To:* mse-users at lists.mapserverfoundation.org
> *Subject:* problems with new release
> Hello,
> I've two problems with the new version:
> - I can't load data in my site because I get a invalid format file
> DB XML error.
> [HC] To get a better understating of steps to reproduce, could
> you tell how you are loading data and what is the data type?
> - I've installed MapGuide server 1.0.0 and webExtensions for
> ASP.NET. The site in IIS is configured automatically and test
> conections works fine, the site administrator is ok and I've loaded
> Sheboygan.mgp succefully. The error occurs when I try to open the
> http://localhost/mapguide/mapviewernet/ajaxviewer.aspx. --> "Intented
> to read or write in protected memory".
> [HC] This URL as such wouldn't work. You might have already done
> this but if not, setup .Net sample application as per instructions in
> Installing the MapGuide Sample Data and Application
> <https://mapguide.osgeo.org/docs/InstallMapGuideSamples.pdf> and try
> http://localhost/mapguide/dotnetviewersample/ajaxviewersample.aspx or
> other URLs as mentioned in the instructions doc. You could also try
> some other operations via http://localhost/mapguide/mapagent/index.html.
> Note: My local machine runs:
> Windows XP Pro.
> IIS 5.1
> ASP.NET 2.0.50727
> MapGuide Server 1.0.0
> WebExtensions for ASP.NET
> thanks.
> *Antonio Lucas*
> *Software Engineer*
> alucas at srtec.com <mailto:alucas at srtec.com>
> www.srtec.com <http://www.srtec.com>
> 963·959·513
> Fax 963·731·756
> SER&TEC
> avda. Ausias March 79 - 1
> 46013 Valencia
Hi Hartesh,
Hi follow all steps that appears in the 'Getting Started' that comes
with Autodesk Studio to load for example SHP's or SDF's:
1- Create Folder Structure
2- Drag SHP's to load procedure
3- Select Datum
4- Click on 'Load Procedure' button and I get the folloing error message:
'An exception occurred in DB XML component. Error: XML Indexer: Fatal
Parse error in document at line, 1, char 1. Parser message: Invalid
document structure'
Thanks.
Antonio Lucas
Software Engineer
alucas at srtec.com <mailto:alucas at srtec.com> www.srtec.com
963·959·513
Fax 963·731·756
SER&TEC
46013 Valencia
Skipped content of type multipart/related
More information about the Mapguide_users
