[mapguide-users] JSP not working with basic installation
Chris Claydon chris.claydon at autodesk.com
Fri Mar 10 16:48:47 EST 2006
Hi Pierre,
I recently ran into the same problem. I had to make a few changes to get
it working...
1)       Set the JAVA_HOME environment variable to point to my Java
installation (in my case: C:\Program Files\Java\jdk1.5.0_06)
2)       Add the following redirect statements to the Apache httpd.conf
file (located in C:\Program
Files\MapGuideOpenSource\WebServerExtensions\Apache2\conf) :
Redirect /mapguide/mapviewerajax/
http://<HostName>:<Port>/mapguide/mapviewerjava/ajaxviewer.jsp
Redirect /mapguide/mapviewerdwf/
http://<HostName>:<Port>/mapguide/mapviewerjava/dwfviewer.jsp
3)       Re-start the Apache server.
4)       Start Tomcat, by running startup.bat in the folder C:\Program
Files\MapGuideOpenSource\WebServerExtensions\Tomcat\bin
These steps are actually described in the following document, but
they're a little hard to find:
https://mapguide.osgeo.org/docs/InstallConfigureMapGuideOnWindows.pdf
I hope this information helps.
Chris Claydon.
  _____
From: Pierre Cardinal [mailto:pierre.cardinal at sympatico.ca]
Sent: Friday, March 10, 2006 1:38 PM
Subject: [mapguide-users] JSP not working with basic installation
Hi everyone,
With the following URL
http://127.0.0.1:8008/mapguide/javaviewersample/dwfviewersample.jsp ,
the result is always
Service Temporarily Unavailable
The server is temporarily unable to service your request due to
maintenance downtime or capacity problems. Please try again later.
  _____
Apache/2.0.55 (Win32) mod_fastcgi/2.4.2 mod_jk/1.2.15 Server at
127.0.0.1 Port 8008
I have no problem with PHP.
http://127.0.0.1:8008/mapguide/phpviewersample/dwfviewersample.php
Regards,
Pierre Cardinal
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060310/ebb6162a/attachment.html
More information about the Mapguide_users mailing list
