.NET Installer Problem and Fix
    Andy Morsell
    amorsell at spatialgis.com
    Sat Mar 11 18:22:14 EST 2006
I believe this was a problem for some .NET web extensions installs in the
0.91 release, but I just ran into it on a fresh install of 1.0 on Windows
2000 Server IIS.  The symptoms: when running the sample .NET application,
you get the following error (you may first have to turn on custom errors in
a web.config file):
Server Error in '/mapguide/dotnetviewersample' Application.
The path '/mapguide/dotnetviewersample/App_GlobalResources/' maps to a
directory outside this application, which is not supported.
Description: An unhandled exception occurred during the execution of the
current web request. Please review the stack trace for more information
about the error and where it originated in the code.
Exception Details: System.Web.HttpException: The path
'/mapguide/dotnetviewersample/App_GlobalResources/' maps to a directory
Either the web extensions installer or IIS adds a backslash to the main
application definition in IIS.  In IIS, right-click on the mapguide virtual
directory, go to Properties, and then look at the local path value.  If you
are getting this error, it will probably read: C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\.  Delete the final
backslash after www and that should fix the problem.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060311/afea4c5f/attachment.html
More information about the Mapguide_users
