[mapguide-users] New configuration problems
    Bill Dhimitri
    bill.dhimitri at autodesk.com
    Sun Mar 12 08:40:47 EST 2006
Hi Eric,
The "version is incompatible" message probably means that you have an
old Studio.  A new one got posted last week to
www.autodesk.com/mapguidestudio with a version number of 1.0.0.16407
(you can use the Help About dialog to confirm the version). If you
download and install the new one, that should fix your problem
Bill
  _____
Sent: Sunday, March 12, 2006 8:35 AM
To: users at mapguide.osgeo.org; ericbrown at netxn.xom
Subject: RE: [mapguide-users] New configuration problems
Hi Eric,
The mgp file itself is just a zip file containing all the map resources.
Sometimes Internet Explorer changes the extensions of files it
recognizes, so it likely renamed it to .zip when it downloaded it. Just
rename it to .mgp.
As far as the Studio problem, let's wait for someone else (who knows
better) to answer that. But I am puzzled that you say MapServer
Studio... That's what the 0.9 version was called, the current one should
say MapGuide Studio when it starts up.
Traian
	-----Original Message-----
	Sent: Sun 3/12/2006 3:14 AM
	Cc:
	Subject: [mapguide-users] New configuration problems
	All...
	Just downloaded MapGuide & Mapserver Studio.
	While the Admin appears to function fairly properly - I can't
connect from studio, receiving the following message: "The Studio
version is incompatible with the site version."
	Since I downloaded both files today my assumption would be that
all would be synched properly.
	Additionally, though I believe these may be related based on
other posts.. the sheboygan.mgp download file isn't a .mgp but rather a
.zip file doesn't include a  the sheboygan.mgp file.  And I've tried
just putting the .zip file in the C:\Program
Files\MapGuideOpenSource\Server\Packages folder to no avail, the admin
doesn't see a package.
	So.. I'm at somewhat of an impasse because I can't get the demo
apps to run because of no data, and I can't play with the development
tool due to a version conflict.
	Any assistance would be greatly appreciated.
	-- Eric
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060312/ab560ccd/attachment.html
More information about the Mapguide_users
