[mapguide-users] Norton Antivirus 2006 - Internet Worm Protection killed MG Open Source install
Jason Birch
Jason.Birch at nanaimo.ca
Tue Mar 14 02:03:06 EST 2006
Yep, disabling that rule was the course I took.
Just tested adding mgserver.exe with permissions to inbound/outbound port 2801, and that seemed to work also.
Jason
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: Mon 2006-03-13 9:53 PM
Subject: RE: [mapguide-users] Norton Antivirus 2006 - Internet Worm Protection killed MG Open Source install
I have the same version here at home. I just took a quick look and NAV lets you customize your internet worm protection settings. For example, under "Trojan Horse Rules" you can explicitly disable the check for the "Phinneas ..." trojan horse. A better solution would probably be to add a new General Rule that allows communication on port 2801, or maybe just adding mgserver.exe as a trusted program is sufficient.
I don't have MapGuide on my home computer so I couldn't do any testing. If you have a chance try one or more of these settings. If it works then we have a simple workaround for the time being.
Walt
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, March 14, 2006 12:30 AM
Oops, just remembered about this.
I'm running NAV 2006 for Windows XP/2000 (retail) version 12.2.0 13
Jason
Sent: Thu 2006-03-09 7:58 AM
Jason,
Can you supply the exact version of NAV that you're using? Corporate /
personal version / major rev / minor rev? I think the About Box also
gives details.
Thanks,
Walt
-----Original Message-----
Sent: Thursday, March 09, 2006 2:50 AM
Subject: [mapguide-users] Norton Antivirus 2006 - Internet Worm
Hi all,
Just a word of warning. If you're running current Norton AV, it may
kill your MapGuide Server install, detecting MgServer.exe as "Default
Block Phinneas Phucker Trojan horse" because it opens port 2801 on all
local network adapters.
ADSK, can you work with Norton to prevent this?
Jason
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060313/b94b6cbe/attachment.bin
More information about the Mapguide_users
