[mapguide-users] Build error in MapGuide Oem Components [was: Build error in Oem Components of fdo-3.0.0_G001.tar.gz]
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Wed Mar 15 13:57:30 EST 2006
Some progress on this:
1/ Open PackageVersionExtension.h and add the following lines near the top:
#ifdef minor
#undef minor
#endif
#ifdef major
#undef major
#endif
2/ Go to the OEM/DWFTK7.1/develop/global/src/dwf folder and open configure.in.  Find the two occurrences of "-pedantic" and remove them (but not "-pedantic-errors").
3/ Rerun build_oem.sh.  The DWF components should now build.
BTW, the fixes for this have been submitted - see https://mapguide.osgeo.org/servlets/Scarab/id/MG90.
Walt
-----Original Message-----
Sent: Tuesday, March 14, 2006 2:57 AM
Subject: Re: [mapguide-users] Build error in MapGuide Oem Components [was: Build error in Oem Components of fdo-3.0.0_G001.tar.gz]
Hi Nicol
i think we have a similarly problem. I am also on a Debian box.
In file included from ../../../dwf/package/writer/PackageWriter.h:42,
                 from ../../../dwf/package/Units.h:31,
                 from
../../../dwf/package/reader/EModelSectionDescriptorReader.
h:33,
                 from EModelSectionDescriptorReader.cpp:21:
../../../dwf/package/writer/PackageVersionExtension.h:96: error: parse error
   before `int'
../../../dwf/package/writer/PackageVersionExtension.h:106: error: parse
error   before `int'
make[9]: *** [EModelSectionDescriptorReader.lo] Fehler 1
make[9]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package/reader'
make[8]: *** [all-recursive] Fehler 1
make[8]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package'
make[7]: *** [all-recursive] Fehler 1
make[7]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf'
make[6]: *** [all-recursive-am] Fehler 2
make[6]: Leaving directory
make[5]: *** [all-recursive] Fehler 1
make[5]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src'
make[4]: *** [all-recursive] Fehler 1
make[4]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global'
make[3]: *** [all-recursive] Fehler 1
make[3]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/mapguide/install/mapguide-1.0.0/Oem'
make: *** [all-recursive] Fehler 1
gcc (GCC) 3.3.5 (Debian 1:3.3.5-13)
If you find a solution......  .
Thanks
Sacha
Nicol Hermann schrieb:
>Hi Traian,
>many thanks for your help. You are absolutely right. I refer to the Oem
>Components in the Mapguide 1.0.0 distribution. Sorry for the confusion.
>Your patch fixes my problem. Sadly i get a new one. See below.
>These compiling errors are difficult to recognise because the build
>script (build_oem.sh) do not stop when the error occur.
>Is there a way to move this process under the control of the
>general ./configure script?
>Attaches the new error.
> g++ -DHAVE_CONFIG_H -I../../.. -g0 -O2 -pipe -pedantic -Wall
>-Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef
>-Wstrict-prototypes -fforce-addr -fomit-frame-pointer -finline-functions
>-ffast-math -fno-strict-aliasing -c EModelSectionDescriptorReader.cpp
>-MT EModelSectionDescriptorReader.lo -MD -MP
>-MF .deps/EModelSectionDescriptorReader.TPlo  -fPIC
>-DPIC-o .libs/EModelSectionDescriptorReader.o
>from ../../../dwf/package/reader/EModelSectionDescriptorReader.h:33,
>error
>   before `int'
>error
>   before `int'
>make[3]: *** [EModelSectionDescriptorReader.lo] Fehler 1
>`/home/nicol/public_html/foundation/source/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package/reader'
>`/home/nicol/public_html/foundation/source/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package'
>`/home/nicol/public_html/foundation/source/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf'
>make: *** [all] Fehler 2
>Many thanks
>Nicol
>>Hi,
>>You say you are building FDO, but the error happened when building the
>>DWF toolkit, which is part of MapGuide. Did you build FDO already and
>>are now compiling MapGuide? Anyway, I fixed this in subversion, and
>>here is the relevant diff for the file (line 155 and onwards).
>>--- UUID.cpp    (revision 276)
>>+++ UUID.cpp    (working copy)
>>@@ -152,10 +152,10 @@
>>     // cccccccc-bbbb-1aaa
>>     // note the 1 indicates a time-based uuid with a known or random
>>host id
>>-    nTimestamp = ((nTimestamp << 32) & 0xffffffff00000000) |
>>-                 ((nTimestamp >> 16) & 0x00000000ffff0000) |
>>-                 ((nTimestamp >> 48) & 0x0000000000000fff) |
>>-                                       0x0000000000001000;
>>+    nTimestamp = ((nTimestamp << 32) & 0xffffffff00000000LL) |
>>+                 ((nTimestamp >> 16) & 0x00000000ffff0000LL) |
>>+                 ((nTimestamp >> 48) & 0x0000000000000fffLL) |
>>+                                       0x0000000000001000LL;
>>It's strange that it compiles fine on 3.2.3 and 4.0.2 but not on the
>>one in the middle (3.3).
>>Traian
>From: Nicol Hermann [mailto:mapserver at geoworld.de]
>Sent: Friday, March 10, 2006 6:50 AM
>Subject: [mapguide-users] Build error in Oem Components of
>Hi List,
>it tried to build the new fdo release (fdo-3.0.0_G001.tar.gz) on my
>debian 32 bit sarge box.
>During the compilation of the Oem product 'Oem/DWFTK7.1' with
>build_oem.sh the following error occurred.
>make[2]: Entering directory
>evelop/global/src/dwfcore/ansi'
>source='UUID.cpp' object='UUID.lo' libtool=yes \
>depfile='.deps/UUID.Plo' tmpdepfile='.deps/UUID.TPlo' \
>depmode=gcc3 /bin/sh ../depcomp \
>/bin/sh ../libtool --mode=compile g++ -DHAVE_CONFIG_H  -I../..    -g0
>-O2 -pipe -pedantic -Wall -Wno-long-long  -Wnon-virtual-dtor
>-Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
>-fomit-frame-pointer -finline-functions -ffast-math -fno-strict-aliasing
>-c-o UUID.lo `test -f 'UUID.cpp' || echo './'`UUID.cpp
> g++ -DHAVE_CONFIG_H -I../.. -g0 -O2 -pipe -pedantic -Wall
>-ffast-math -fno-strict-aliasing -c UUID.cpp -MT UUID.lo -MD -MP
>-MF .deps/UUID.TPlo  -fPIC -DPIC -o .libs/UUID.o
>UUID.cpp: In member function `void
>DWFCore::DWFUUIDImpl_ANSI::_generate()':
>UUID.cpp:155: error: integer constant is too large for "long" type
>make[2]: *** [UUID.lo] Fehler 1
>Does anyone know how to fix this?
>gcc --version
>Many thanks
>Nicol
>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: users-help at mapguide.osgeo.org
Gruss
Sacha
Kreis AG Sargans
Ingenieur- und Vermessungsbüro
Kantonsschulweg 12
CH-7320 Sargans(Hauptbetrieb)
Tel. +41 (0)81 720 05 00
Fax +41 (0)81 720 05 05
Homepage : http://www.mkreis.ch
E-Mail   : mailto:s.genoud at mkreis.ch
More information about the Mapguide_users
