[mapguide-users] multiple extent attributes on a layer
Andy Morsell
amorsell at spatialgis.com
Wed Mar 15 14:30:29 EST 2006
In the "URL activated for feature" area of the layer definition, go into
the Text Expression and build an expression like you would for a Tool tip.
An example when viewed using the Advanced option is:
concat('http://www.spokanecounty.org/pubpadal/search.aspx?Identify=pubmaps&a
mp;txtSelParcel=', PID)
Note that I have to use & instead of & in my string. If you use just &,
the entire tooltip will not display (at least with the .NET web extensions).
This may be considered a bug, but I'm not sure.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
Sent: Wednesday, March 15, 2006 11:15 AM
Subject: Re: [mapguide-users] multiple extent attributes on a layer
That works... go figure - I'm too used to laying in the data by hand (Map
file).
That's much better.
Another question - how would I link off to an url when a feature is
selected? The documentation indicates that it can be done, but the syntax
is missing.
-- Eric
----- Original Message -----
From: "Traian Stanev" <traian.stanev at autodesk.com>
To: <users at mapguide.osgeo.org>
Sent: Wednesday, March 15, 2006 10:36 AM
Subject: RE: [mapguide-users] multiple extent attributes on a layer
Hi Eric,
You are not actually theming on the attribute. From the screenshot it
looks like you created overlapping scale ranges with a different style
for each scale range. What you want to do is set different attribute
themes in a single scale range in the lower dialog (where the "Theme..."
button is). See the attached screenshot for an example.
Traian
Sent: Wednesday, March 15, 2006 12:58 PM
Kori,
Here's a picture of my layer - I've described 4 separate extents.
0-22000 is all roads (except Highways and Ramps)
0-44000 is Arteries (Class = 'A')
0-infinity is Class='H' in yellow - highways
0-infinity is Class='R' in orange - ramps
And - no - once you get down to 22000 - the Highways and Ramps and
Arteries
stop displaying.
Please advise,
-- Eric
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
