[mapguide-users] RE: Measure tool
Eric Brown ericbrown at netxn.com
Thu Mar 16 23:33:21 EST 2006
You're ahead of me - I couldn't figure out how to add an issue.
-- Eric
  ----- Original Message -----
  Sent: Thursday, March 16, 2006 7:49 PM
  Subject: [mapguide-users] RE: Measure tool
  Good deal on those fixes.
  This is where using the Project Tracker confuses me.  I entered this issue as MG121 this morning and then it was duplicated as MG127.  How is inputting issues into Project Tracker best coordinated?  I've just been sticking issues into there as I see them to make sure they are somehow logged beyond the users listserv and to make sure they aren't overlooked.
  Andy
  From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
  Sent: Thursday, March 16, 2006 5:31 PM
  Subject: RE: [mapguide-users] RE: SPAM-LOW: [mapguide-users] Measure tool
  Andy, Eric,
  One of the problems was fixed today. The distance is now displayed according to the viewer settings.
  The other problem - causing the red lines not to appear - is due to wrong conversions between coordinate systems, and should be fixed shortly.
  Alain
  From: Andy Morsell [mailto:amorsell at spatialgis.com]
  Sent: Thursday, March 16, 2006 8:23 AM
  Subject: [mapguide-users] RE: SPAM-LOW: [mapguide-users] Measure tool
  Yes, I see the same thing, no line draws in either the DWF or AJAX viewers.  And, the distance is always kilometers regardless of how you have your units setup in viewer options.  Maybe this will convince the U.S. to finally go metric ;)
  Andy Morsell, P.E.
  Spatial Integrators, Inc.
  http://www.SpatialGIS.com
  Sent: Thursday, March 16, 2006 7:15 AM
  Subject: SPAM-LOW: [mapguide-users] Measure tool
  Is there a bug with the "Measure" tool?
  I can use it - but it doesn't draw a line (it does provide a legend - red line) but doesn't show the physical line(s).  It also appears to be incorrect - at least in terms of actual distance.
  -- Eric
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060316/a8ec4b4b/attachment.html
More information about the Mapguide_users mailing list
