[mapguide-users] Mapguide Service not starting automatically
Butler, Juan P
jpbutler at co.pinellas.fl.us
Mon Mar 20 14:17:08 EST 2006
Yeah...I just checked the event log. All it stated was that the
"Mapguide Server services failed to start due to the following error:
The service did not respond to the start or control request in a timely
fashion.
Juan Butler
jpbutler at pinellascounty.org
Sent: Monday, March 20, 2006 2:08 PM
Subject: Re: RE: [mapguide-users] Mapguide Service not starting
automatically
Yes I too am experiencing problems, but have just chalked it up to too
much trying to load on start up (i also have Oracle on this box). The
Windows event viewer states Timeout (30000 milliseconds) waiting for the
MapGuide Server service to connect is the root cause. I searched the
MSDN and did not really find any solutions - so for now i am just
manually strating the service after it fails.
Below are the contents of my log file
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2006-03-15T19:42:07> Administrator
Error: Resource was not found: Library://ATest.WebLayout
StackTrace:
- MgOpGetResourceContent.Execute line 128 file
c:\build_tux_area\mgdev\server\src\services\resource\OpGetResourceConten
t.cpp
- MgServerResourceService.GetResourceContent line 671 file
c:\build_tux_area\mgdev\server\src\services\resource\ServerResourceServi
ce.cpp
- MgApplicationRepositoryManager.GetResourceContent line 343 file
c:\build_tux_area\mgdev\server\src\services\resource\ApplicationReposito
ryManager.cpp
- MgResourceDefinitionManager.GetResource line 695 file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionM
anager.cpp
- MgResourceContentManager.GetDocument line 258 file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceContentMana
ger.cpp
- MgResourceDefinitionManager.GetDocument line 856 file
anager.cppResource was not found: Library://ATest.WebLayout
<2006-03-15T19:46:48> Administrator
StackTrace:
t.cpp
ce.cpp
ryManager.cpp
anager.cpp
ger.cpp
----- Original Message -----
From: Bruce Dechant <bruce.dechant at autodesk.com>
Date: Monday, March 20, 2006 9:46 am
Subject: RE: [mapguide-users] Mapguide Service not starting
automatically
> Juan,
> Is there any information in the MapGuide "Error.log" that might
> indicatewhy the service failed to start?
> Could you also try running the server from the command line to see if
> that works? (I'm just trying to see if the server can actually startup
> properly)
> To start the server from the command line do the following:
> 1) Open a "Command Prompt" windows
> 2) Change to the directory where the server is installed.
> Defaultis here: C:\Program
> Files\Autodesk\MapGuideEnterprise2007\Server\Bin
> 3) At the command prompt type "mgserver /interactive"
> without the
> double quotes.
> The server should indicate it has started. If it does not please
> have a
> look in the "Logs" folder of C:\Program
> Files\Autodesk\MapGuideEnterprise2007\Server and check the "Error.log"
> file for the reason why the server could not start.
> Please let me know what happens after trying the above.
> Thanks,
> Bruce
> _____
> From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
> Sent: Monday, March 20, 2006 8:26 AM
> Subject: [mapguide-users] Mapguide Service not starting automatically
> Is anyone running into an issue when restarting their server or in my
> case laptop, and the Mapguide Service not automatically starting on
> reboot? It's set to automatic.
> Thanks.
> Juan Butler
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060320/2482bfc5/attachment.html
More information about the Mapguide_users
