[mapguide-users] MapGuide Install question
Francisco Javier Rojas Duran
francisco.rojas at dasoft.com.mx
Tue Mar 21 12:06:14 EST 2006
Be Careful, MapGuide OpenSource needs Autodesk DWF Viewer 6.5 , and Autodesk
MapGuide needs Autodesk MapGuide Viewer 6.5 , It is not the same
Viewer / plug - inn.
And you can have installed both of them (The Viewers only).
Regards.
Ing. Francisco Javier Rojas Durán
IT Manager - Oracle Specialist
Division de Tecnologias de Información
Grupo DaSoft S.A. de C.V.
-----Mensaje original-----
De: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Enviado el: Lunes, 20 de Marzo de 2006 06:13 p.m.
Para: users at mapguide.osgeo.org
Asunto: RE: [mapguide-users] MapGuide Install question
v6.5 is the latest DWF Viewer
-----Original Message-----
Sent: Mon 3/20/2006 6:56 PM
Cc:
Subject: RE: [mapguide-users] MapGuide Install question
Yes - completely uninstall the old MapServer Enterprise.
Make a backup of any folders if you need to.
The un-install of the 6.5 ActiveX control is not necessary.
You will want to install the lastest DWF viewer though...
Kori Maleski BSc.
Senior Technical Consultant
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL
403.770.1917
FAX
877.691.9149
TOL
877.691.9171
www.pat.ca
________________________________________
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: March 20, 2006 3:55 PM
Subject: [mapguide-users] MapGuide Install question
Do I need to uninstall MapServer Enterprise Server/Web Extensions
before
installing MapGuide Server/Web Extensions?
And what about the older version of Autodesks MapServer Studio?
Uninstall
first?
And Autodesk Mapguide Viewer Active X control Version 6.5?
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
